I just started fab on a new twin lid grapple design. Key features
* All AR400 laser cut parts in 0.25, 0.131 and 0.375 inch thickness
* 8 inch tine spacing, bottom tines are about 32 inches deep on the inside dimension, jaws open about 39 inches, overall about 68 inch width
* Designed to handle either 3 or 2.5 inch utility cylinders with 8 inch stroke
* finished weight estimated 750 lbs using 1/4 inch inner tines and 3/8 grapple
* 10,000+ lbs design load capable for use on SS or CTL, this design is to be tough yet light weight, great for my M59's ~4,000lbs lift capacity
* I've tweaked the design to allow me to grab and pull logs from the ends, pick/grab smaller 6 inch diameter rocks, grab odd shaped items like root balls and large branched logs, be able to rake the ground to pick up small branches, a larger base fork to make hauling firewood logs easier and to be able to grab more brush in one bite
* grease-able protected pins that are locked in place with retaining bolts
First image shows a 3D rendering. Second image shows the flat pack of parts. Third image shows the initial layout for welding. Fourth image shows my old single lid root grapple I bought which was heavy and designed using 1/2 inch mild steel.
Why am I making this?
I disliked my old single lid grapple as it seemed like I was constantly fixing it. The grapple struggled with large rocks and grabbing big bundles of logs. I wanted to upgrade my heavy single lid grapple for a twin lid design that is stronger and lighter. I can't find an OEM unit I want in stock and I've been quoted CDN$6K to $6.5K on a new one wth a 8 to 12 month wait list. I will fabricate this one new for about 2/3 the cost or about the price of a beat up used one that I've been finding online.
Here's the market research bit..
How many users would want to fab their own grapples if they could select and buy all the components and have it shipped as a flat pack kit? The laser cut parts are the hard to get items. Stuff like structural tubing, fittings and cylinders are better sourced locally instead of shipping parts from Canada that I get out of the US. I focus on locally sourced materials. My laser shop takes about a week to cut parts for me and finish is pretty good. Shipping would be on a 32~36 inch pallet shrink wrapped with total weight of the flat pack parts about 450 lbs for what you see in the image above.
My thinking is that there are probably guys like me who wouldn't mind an ikea approach to grapple attachments. I keep seeing all this cheap sh*t imported stuff out of china with poor designs, crappy welds and thick globs of high hide paint and think no, I don't want to waste more time fixing someone else's problems. Bite the bullet, do it now and make it the way I want it. If I could find the parts I want online and buy them I would - but I can't find them.
Obviously buyers need to have some skills and tools at hand to do some welding/fitting/grinding etc. Price is always the question. Shipping LTL from Canada isn't cheap so the more I can fit on a small pallet the better. Steel prices are out of this world at the moment, however, I can get 10 sets of parts cut cheaper than one offs. Economies of scale blah blah blah.
Fill in the survey!
Fill in the survey!
