Gr2120 not shutting off
Canine
KH30
Mar 5, 2021
UK
GR2120 not shutting off
Changed solonoid
Checked fuses
Can’t find timer relay.
can anyone point out where the timer relay is.
Many thanks
Canine
KH30
Mar 5, 2021
UK
Thanks TBK5x, spot on.
now I’m even more confused. still not shutting off.
I have two GR2120s, I have checked fuses, changed solonoid and timer relay.
I’m about to dive in on the switch then wiring.
anyone got any suggestions?
it’s so frustrating…
tbk5
L3710, L3010, ZD1211, RTV900xt, GR2100, lots of 3pt equipment
Sep 24, 2013
181
Central AL
You need a wiring diagram. kubotabooks.com has a WSM for the GR2100EC. Maybe the wiring is similar.
Does the stop solenoid actuate (audible click or you can watch it move) when you turn the key on (without starting) and release when you turn the key off (delayed). You should also test your key switch.
How did you shut it off?
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
We're all talking about the fuel cutoff solenoid and not the starter solenoid, correct?
Grab, move and hold the plunger in the \opposite direction to wherever it is when the things running.
(presumably it's outside running right now, correct?)
lmichael
Kubota G2160
Apr 23, 2021
679
317
Rockford IL area
I gave up on it. Simply ran a cable and pull knob to my dash. To turn the machine off, I simply turn off the key and pull the knob. EZ. Nothing to break or burn out
lmichael
Kubota G2160
Apr 23, 2021
679
317
Rockford IL area
Cables don't break? Do you also have ocean front property in Arizona?
It's a very stout cable and not doing anything strenuous. Only pulling on the fuel shutoff. So, yeah who knows.......................might wear out after 100 years of that use.
