If it is indeed a factory item you can buy a replacement from Kubota. Yes, it may be expensive.It is a factory item. I had to cut it off the wiring harness. No plug.
Almost certainly, you will not be able to buy it elsewhere.
Here are the boards inside the box I saw a web page marked on one of the boards I going to try itYes I bought it new in 2014 it may have other things wrong with it. I really do not understand why you guys think I am lying. Erect is the info that was on the tag on the tractor, jt194, tops model #sfb-f50, tops ser # 51284. I did order a shop manual have not got it yet. The box was on top of the motor. I bought bit at a kubota dealer. The wiring diagrams that I have found so far do not show it. I reall do want to thank you for yours and others replies. Thanks
There is no such box on top of the motor of my B3350.Here are the boards inside the box I saw a web page marked on one of the boards I going to try it
Guess you are wThere is no such box on top of the motor of my B3350.
Does your B3350 have both DPF and reformer in place?
it has a reformer for sure form the place that makes the emulator it was made to cut down on the errors sent to the ecu. Here is the description from their site. The Kubota engine used in Kubota engine vehicles uses adblue fluid in some models and only DPF filter is available in others. In vehicles that only have a DPF filter and do not use Adblue fluid, the error rate is higher than in vehicles using Adblue fluid because the DPF filter fills faster than the vehicles used. For this reason, it will offer a smooth operation thanks to the Kubota DPF emulator developed to minimize the error rate in Kubota vehicles using only DPF filters that do not use Adblue fluid.There is no such box on top of the motor of my B3350.
The info from their site says it is used to cut down errors. The Kubota engine used in Kubota engine vehicles uses adblue fluid in some models and only DPF filter is available in others. In vehicles that only have a DPF filter and do not use Adblue fluid, the error rate is higher than in vehicles using Adblue fluid because the DPF filter fills faster than the vehicles used. For this reason, it will offer a smooth operation thanks to the Kubota DPF emulator developed to minimize the error rate in Kubota vehicles using only DPF filters that do not use Adblue fluid.I checked that website and it is in Turkey and they sell emulators to defeat the DPF system.
If you read through their emulator page, it is setup to remove the DPF.Guess you are w
Works good - eliminates annoying DPF errors and regens. It also gives you easy to diagnose and repair vehicle fires and toasted wiringHis is what I found on the site The Kubota engine used in Kubota engine vehicles uses adblue fluid in some models and only DPF filter is available in others. In vehicles that only have a DPF filter and do not use Adblue fluid, the error rate is higher than in vehicles using Adblue fluid because the DPF filter fills faster than the vehicles used. For this reason, it will offer a smooth operation thanks to the Kubota DPF emulator developed to minimize the error rate in Kubota vehicles using only DPF filters that do not use Adblue fluid. Sailteknoloji.com
All Kubota B3350 tractors sold in the US have DPFs and none use diesel exhaust fluid.His is what I found on the site The Kubota engine used in Kubota engine vehicles uses adblue fluid in some models and only DPF filter is available in others. In vehicles that only have a DPF filter and do not use Adblue fluid, the error rate is higher than in vehicles using Adblue fluid because the DPF filter fills faster than the vehicles used. For this reason, it will offer a smooth operation thanks to the Kubota DPF emulator developed to minimize the error rate in Kubota vehicles using only DPF filters that do not use Adblue fluid. Sailteknoloji.com
.I downloaded the B3350 WSM there's NO '11 pin black box' in any of the wiring diagrams and none of the engine pictures show it either.I couldn't see any 11 pin connector in the diagrams either.
That leads me to believe, like others, that it is a 'DPF bypass' and the name 'emulator' kinda says so.
There's no way Kubota would add the box to bypass their DPF equipment so it's a mystery to 'us' as to who,when,where,why the device was added. It's not that we think you're lying but the device isn't OEM.
Curious, when you bought the tractor in 2014 how many hours was on it?
Again, pictures of the engine and wiring would be nice to see.
The Kubota engine used in Kubota engine vehicles uses adblue fluid in some models and only DPF filter is available in others. In vehicles that only have a DPF filter and do not use Adblue fluid, the error rate is higher than in vehicles using Adblue fluid because the DPF filter fills faster than the vehicles used. For this reason, it will offer a smooth operation thanks to the Kubota DPF emulator developed to minimize the error rate in Kubota vehicles using only DPF filters that do not use Adblue fluid.This brings up an interesting question, if you bought the tractor brand new, then who placed the emulator on there? If you didn't do it, then it would appear that the dealer would be the next logical guess on who placed the illegal device on there.
Yes, I read that on their site also. I also went to the PDF instructions and read where it accomplishes this lower error rate by eliminating the DPF system.The Kubota engine used in Kubota engine vehicles uses adblue fluid in some models and only DPF filter is available in others. In vehicles that only have a DPF filter and do not use Adblue fluid, the error rate is higher than in vehicles using Adblue fluid because the DPF filter fills faster than the vehicles used. For this reason, it will offer a smooth operation thanks to the Kubota DPF emulator developed to minimize the error rate in Kubota vehicles using only DPF filters that do not use Adblue fluid.
I would think twice about installing not UL or CE certified aftermarket electrical equipment unless I parked the machine in a field and was hoping for an insurance claim. The OP is playing with fire and only a couple of wires got burned...this time.Works good - eliminates annoying DPF errors and regens. It also gives you easy to diagnose and repair vehicle fires and toasted wiring
TOH
Sail tech has a 2 yr warranty. I would try to get a replacement from them.
whois sailternoloji.com
No match for "SAILTERNOLOJI.COM".
>>> Last update of whois database: 2023-07-10T13:47:38Z <<<
