I have a BH77 backhoe on my LX2610 and I noticed that when the backhoe is installed it does not fit within the mounts like I think it should. Can you post your pictures and comment(even if you think I'm an idiot).
Though I am sure that the pin diameter is correct, why so much side to side slop?
Mine has about the same amount of slop. No spacers that I am aware of.Though I am sure that the pin diameter is correct, why so much side to side slop?
Are there supposed to be spacers in there?
The other two mounts (pictured) it uses seem take care of any side to side movement.Though I am sure that the pin diameter is correct, why so much side to side slop?
I think your fine.Yes, the pin diameter is correct(after some paint wore down) it is the side to side that I am concerned about. The reinforced C-shaped metal hardly touches to the mount on one side. Just wondering if others BH77 are like this or do I have an issue? Or is it because I have a cab(therefore have the extension with a seat)?
I certainly do not understand the why of that design........poor fit?Yes, the pin diameter is correct(after some paint wore down) it is the side to side that I am concerned about. The reinforced C-shaped metal hardly touches to the mount on one side. Just wondering if others BH77 are like this or do I have an issue? Or is it because I have a cab(therefore have the extension with a seat)?
