Trouble starting TG1860
Jriedy85
B2710, TG1860
Jun 17, 2020
84
22
So I just bought this TG1860 a couple weeks ago. I’ve used it a few times to mow. Started right up no problems. Today I went to mow and it wouldn’t start. Couldn’t hear the starter clicking or anything. I could hear like a relay or something turning on but that was it. Was doing some google searching and someone said they had the same issue and they turned the fan and then it would start. So I tried the same thing. Turned the fan about a quarter turn. Hopped back on and it started right up. What could be the issue with that?
Jcandme
L3800 with HST
Jun 27, 2023
Quitman, TX
I have one that did the same thing. I haven’t tried spinning fan yet but would love to see replies.
lmichael
Kubota G2160
Apr 23, 2021
845
439
Rockford IL area
First off be sure all connections are good. Safety switches, battery cables, etc. If all that checks out and still only clicks add a helper relay. Had to do that on my G2160. Best thing ever for it
Jriedy85
B2710, TG1860
Jun 17, 2020
84
22
never heard of a helper relay. Will have to google that.
Jriedy85
B2710, TG1860
Jun 17, 2020
84
22
I bought a whole box of these Amazon.com: 5 Pack - EPAuto 30/40 AMP Relay Harness Spdt 12V, 5-PIN SPDT Bosch Style : Automotive
They come with wire harness, plug, and bracket. I used one for my starter relay installation, another for my tow behind sprayer harness I added, and another for my lighting system I added/upgraded.
View attachment 106860 View attachment 106861 View attachment 106862 View attachment 106863 View attachment 106864 View attachment 106865
So do we just think the starter relay is going bad and needs replaced?
6,275
hmm, how old is this machine ? According to Tractordata it was last made in 2003, so 2 decades ! If true , when were the battery cables replaced ? Really need a test light/meter on the starter solenoid control wire and confirm/dent it IS getting +12 when you turn the ign key to 'start'. If yes, then either an internal starter problem,bad battery cables or bad battery. Since it's a new starter, it shouldn't be bad...but you did bench test before installing ?? How old is the battery and did you remove,sit on bench and fully recharge it ? I suspect bad cables/connections(nuts and bolts). if the cables are NOT OEM style molded one, replace them.
'turned the fan' !????? really ??????
assuming this IS the 18HP diesel, the fan is probably on the water pump,run by the fan belt,so ZERO 'cure' for a 'no start' problem....sigh...gotta love the internet.....
Jriedy85
B2710, TG1860
Jun 17, 2020
84
22
I haven’t replaced anything on this tractor yet as I just acquired it. And I thought the fan thing was crazy but that was the only thing that actually got the thing to start. Idk why or what could be the correlation but it worked.
ve9aa
Apr 11, 2021
1,193
972
NB, Canada
re: FAN......someone's given you some bad advice dude.
Mower switch PUSHED in?
Jriedy85
B2710, TG1860
Jun 17, 2020
84
22
Lol I’m just saying it worked. I don’t know what to tell you. It is crazy. I agree. The blades were not engaged.
Jriedy85
B2710, TG1860
Jun 17, 2020
84
22
Quick google search online and I found 2 other people that said they had the same issue and turning the fan then starting worked. Just so you don’t think I’m crazy. 😂 obviously this isn’t a solution though. Will def be trying the helper relay.
3,646
2,064
The reason turning the engine over using the fan works is that the solenoid does not have enough power to compress the spring in the Bendix drive and twist it to line up the teeth into the slots of the flywheel. The bendix teeth are contacting the flywheel teeth.
When you turn the fan, you are just repositioning the flywheel.
The simplest and most effective solution is to add the started relay which gives the solenoid full power to compress and twist the Bendix as needed to get the teeth to engage.
We keep a box of about 20 of the relays with the relay base that has about 10 inches of wire already on it. Makes installation very simple and quick.
Most of the new equipment has a start relay already in the system.
Jriedy85
B2710, TG1860
Jun 17, 2020
84
22
Will def be adding a relay. Hopefully that stops me from having to do any more silly fan turning. Thanks!
7,611
Sounds to me like Coleman's have what you need! They keep them by the box full. Pay the postage and get what works!
geomiklas
Kubota TG1860
Apr 11, 2026
Lynchburg, VA
I live in Lynchburg, VA, and need to get the parts and schematic to install the relay on my TG1860.
A kit was referenced above for a replacement relay for John Deere.
Another kit was referenced for 5 relays for $17 on Amazon.
Which one of these is the same part I need to fix my clickity-click starter on my Kubota?
Thanks,
George
