Leveling Box BX2680
BotaGuy
BX2680, Box Blade, Bush Hog, Piranha Bar, Boom Pole
Nov 22, 2020
10
Ott16*9*9
Has anyone found an adjustable leveling box that fits a BX? I have looked everywhere for months on end and can't find one. :(
Stomper
2017 L2501. Landpride Mower. Farm King Snow Blower. DIY Root Bucket grapple.
Jun 30, 2017
240
Northern Canada
What do you call leveling box. This a a sweet grader box that would work great. It could be a diy or have someone make it
hodge
Nov 19, 2010
2,959
535
Love, VA
Are you referring to an implement, or an adjustable side link? If it's the latter, Weavers Compact Tractor carries a couple different sizes. I bought one for my 790; it required a sleeve to adapt the top mount, but otherwise it fit great.
5,604
Don’t know what length you’re needing (extended and retracted) but it seems like that would be near impossible to source unless someone makes them specifically for a BX / JD1025 size machine as they were pretty common on larger tractors at one time but not so much on SCUTs.
It is more likely you’d be able to source a hydraulic replacement although that has the downside of $$$$, especially if you don’t already have a remote available to run it.
BotaGuy
Nov 22, 2020
10
Ott16*9*9
Thanks to all! I looked at Weavers and a few others but, as stated above, they are pretty much specific to certain model tractors. None of the ones I found were small enough to fit my "toy" tractor. :D I thought maybe I missed one.
4,696
A question are you looking to move dirt, gravel, or just level out your drive way? AND FYI you do not have a toy tractor, she is a real work horse! Now a red neck way if all you want to do is even things is an old metal box spring. They aint pretty but they work very well leveling things out,, We used one when the folks built the new house, it bounced around and picked up lots of rocks and after a few passes Mom had a nice level yard.. Just a thought
BotaGuy
Nov 22, 2020
10
Ott16*9*9
I have a 4' box blade and I want to angle it so that I can slope the very outside edge of my 600' long straight dirt driveway. I want my neighbors water runoff to go down the edge of the driveway instead of washing out the entire driveway. Kinda like making a trough I guess. It's just a PITA to adjust it with the stock leveler. And YES, my BX is awesome. I live on 5 wooded acres. I had an L2050 for years but it was too big for my needs. I love my BX. :D
Smokeydog
Jun 2, 2020
757
729
knoxville, Tennessee
Weaver’s leveling box on B26. Buy for size then modify to fit. B26 has little T-Rex 3pt arms.
5,187
Weaver’s leveling box on B26. Buy for size then modify to fit. B26 has little T-Rex 3pt arms. View attachment 106746
I had to modify one for my 1989 Shibaura built Ford 1920 FEL.
It works just fine, but it is necessary to get off the tractor to adjust.
The leveling box on my old Ford 8N can be adjusted while remaining in the seat.
hodge
Nov 19, 2010
2,959
535
Love, VA
I can adjust mine from the seat (box from Weaver's on my JD 790).
5,187
Do you know your target lengths- shortest being the most important? If the one that I linked will work (size wise), you can adapt the top link to the
Only tractor seat configuration determines usability from seat.
Source of product (Weaver's) makes no difference.
MtnViewRanch
883
332
Lakeside Ca.
To have the implement level side-side, the pin-pin distance on a BX is 13 1/4".
It will be a tight fit to get it to the level point let alone have it adjust for an even amount of tilt to both sides if that is even possible with anything that is readily available that can be modified.
3,341
… I live on 5 wooded acres. I had an L2050 for years but it was too big for my needs. :D
I must say that this comment sort of blows me away! I suppose if you only have 1 acre or may be a half acre of usable property it makes sense.
Just struck a surprising cord in my body I think when I read it.
I suppose I don’t know what a L2050 is… Maybe it is much bigger than I imagined. I was thinking of an L2501 When I read your comment…
BotaGuy
Nov 22, 2020
10
Ott16*9*9
Hard to get between the trees and make turns with the 2050 as it IS larger than the BX. My property is heavily wooded. BX gets thru the trees easily. Not to mention I can drop the FE loader if I want. :D
BadAndy
BX23s TLB-BX2822A Snow blower-LP BB-HLA Forks-Craftsman YT4000 Lawn Tractor
Mar 30, 2021
81
80
BotaGuy.... Did you ever find one? I need one as well.
