Kubota Tractor B7200HST-D hydraulic oil leaking into the crankcase/oil pan
Ed Potthoff
B7200HST-D
Oct 8, 2020
14
Sandia Park, NM
I own a Kubota Tractor B7200HST-D. I have hydraulic oil leaking into the crankcase/oil pan. When I removed the pump to replace it, I noticed damage to the gear that connects to the drive gear in the engine block. When I replace the pump, I will replace the damaged pump gear. However, the drive gear in the engine is also damaged. I believe I need to replace the drive gear in the engine. I have searched everywhere, but cannot find the part number for the drive gear.
1. Can anyone help me with the part number?
2. How do I get the old gear out and the new one in?
Thank you in advance for the help.
Regards,
Ed Potthoff
8,704
Well there is a small issue with what your asking, the B7200HST-D never had a gear driven pump, so someone has swapped some parts or swapped the entire motor.
Need more info and pic's if possible.
The most likely is that it has a B8200 set up in it, but that's a pure guess at this point.
You will need to provide the stamped serial number that is just to the side on the flat of the block next to the injection pump and the tractors full serial number to try and unravel what motor and tractor we are dealing with.
Donystoy
Dec 10, 2013
663
300
Binbrook, Ontario
If I remember correctly the pump on the B7200 that I had, had a male rectangular piece that slipped into a female slot on the end of the injector shaft.
Ed Potthoff
B7200HST-D
Oct 8, 2020
14
Sandia Park, NM
Ed Potthoff
B7200HST-D
Oct 8, 2020
14
Sandia Park, NM
I believe I may have used some wrong terminology in my descriptions in calling the flat end of drive mechanism a gear. I have attached a document that shows what I’m working with. I have owned this tractor for over 10 years and there is no doubt that what I have is a Kubota B7200HST-D Tractor. And I could really use some help. If you still feel that I have something other than a B7200HST-D Tractor I will listen.
Regards,
Ed Potthoff
It was my intent to send you a document to show what I am trying to do however; I got the size of my document to 2809 KB and I'm told it is still too big. I would like to send it.
8,704
You can send the file to me directly:
NIW@orangetractortalks(dot)com
Replace the (dot) with a .
This side?
Tab on hydraulic pump
Or is the damage on the slot on the end of this shaft?
If it is post a picture of thee damage
Ed Potthoff
B7200HST-D
Oct 8, 2020
14
Sandia Park, NM
This side?
to: North Idaho Wolfman
I sent a file to you last night. Did you receive it? The Diagrams above indicates the situation I 'm in. I have the pump in your first diagram on order. I have my fingers crossed that it is the correct pump. My discussions with the vendor confirms all the critical dimensions are correct. The second diagram highlighted area is a fuel camshaft (Item 110.) Will that section (camshaft) need to be replaced, and what is involved in replacing it?
Regards,
Ed Potthoff
5,164
Regards,
Ed Potthoff
Do you have a copy of the parts manual? If not it can be downloaded for free.
Forgot the Photos
Ed
Thatvis a tang drive shaft not a gear. If that tang will mesh with the new oppump clean it up and move on. Worry anout it when the pump stops working.
Ed Potthoff
B7200HST-D
Oct 8, 2020
14
Sandia Park, NM
Dan,
At this point, that's the best recommendation I've had.
Ed
Lencho
B7100hst
Jan 21, 2017
428
101
NM
Hi Ed,
I tend to agree with Old Hokie, if it meshes and turns the pump it will likely work for a long time.
I had the same leak this spring and just replaced the pump seal.
As you say mine was rectangular but yours looks quite symmetrical so perhaps the design was changed?
IMG_0086.jpeg IMG_0087.jpeg IMG_0088.jpeg IMG_0089.jpeg IMG_0090.jpeg IMG_0086.jpeg IMG_0087.jpeg IMG_0088.jpeg IMG_0089.jpeg IMG_0090.jpeg
5,164
Hi Ed,
View attachment 106752 View attachment 106753 View attachment 106754 View attachment 106755 View attachment 106756 View attachment 106752 View attachment 106752 View attachment 106753 View attachment 106754 View attachment 106755 View attachment 106756 View attachment 106752 View attachment 106753 View attachment 106754 View attachment 106755 View attachment 106756
That looks a lot like a vane pump.
