L345DT question
Csdwarf11
L345dt
Jul 4, 2023
Maine
Hey everyone!
I am brand new to the Kubota family. I ended up with an older l345 Seems like a great tractor, everything works as it should, and it seems to run great. The only issue is with secondary reduction section on the front end.
There are 4 bearings holding the vertical bevel gear shaft, and the top two had failed completely. This caused some marginal damage to the 13t (37800-43820) gear that is bolted to the axle. I ordered all the parts to replace the bearings and seals, but I haven’t found the bevel gears.
if I can’t find it, it will probably work, but I hate putting a damaged gear back in.
is there a good source for used parts for these older tractors? Or does anyone have any suggestions?
thanks for taking the time to help me out!
1,443
There is a member here that sells used parts for the older models.
You can send him a private message and ask for what you need.
He is 007Kubotaguy on this forum and may be along to reply to you in a few days?
There should be a envelope somewhere on your screen to send a PM.
I have his business information somewhere and will send it if you don’t get in contact with him, just let me know if you need the information
Csdwarf11
L345dt
Jul 4, 2023
Maine
Awesome! I will reach out and send him a private message. Thank you for the fast reply, and if you think of anything else, please let me know.
thanks again.
1,443
thanks again.
There is (or was) a salvage yard called West Kentucky Tractor but I recall they closed down. You might search for tractor salvage and see if anything comes up.
Csdwarf11
L345dt
Jul 4, 2023
Maine
There is a yard in Maine that has some L345 and L355ss parts - great people!
Link: http://mainetractors.net/Kubota-l355ss/kubota-l355ss-parts.htm
Their list includes some front axle parts. I didn't see the part you're after ( 37800-43820 )
but if you call them and ask they might have something. Take care, Dick B.
Awesome! I have been hunting around and I did not see these guys. Thanks for pointing this out. I will give them a call today. I’ll keep everyone updated. Fingers crossed.
thank you!
