bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
My L3800 has two grease fittings on the front axle. The one in front of the axle is in the manual. It is the front axle support and requires the removal of the breather plug. On the back side of the axle is another fitting where the shaft connects to the axle. This fitting is not shown in the manual. I can never get this fitting it fill with grease. I stopped after putting about a 1/4 of a tube into it today. Should I be seeing it exit somewhere? FWIW, I noticed the axel is marked L3300. Any info appreciated.
