Kubota loader
L2501dt
27
Connecticut
Does anyone know if these threaded bolts with nuts on them are suppose to be tightened or loose.
There are several of them for the pins on loaders. All seem to be loose, was just curious how they should be. Loose or tight
4,668
They are installed loose by the factory.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,868
2,917
Yeah. Some so loose they fell out of mine. Fortunately I'm good about checking my equipment. Safety wired a roll pin in until I could get another bolt.
Edit- they should not be tight though.
N3BP
Sep 20, 2016
473
202
Lebanon, PA
Tighten them up, then back them off a few threads so they can move. As others have said, they need to have some degree of play in them. Your nuts appear to by nylock nuts, which are the correct ones.
4,668
Loose or tight - I doubt it matters.
The bottom two nuts on my bucket sheared off in the first few hours of use. Just a bad over exposed and unprotected design. I replaced with shorter bolts inserted from the bottom, convetional nuts with a thread locker and fully tightened. Two years later and going strong.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,868
2,917
Well, I guess "tight" can be used loosely. Pun intended. When I think "tight" I'm thinking torqued more than snugged up. The loader arm flange isn't going to move. The bolts just keep the pin from sliding out.
5,054
OK... 'snug' enough that they can't fall off, which really means 'tight'.
There's ZERO reason for them to be 'loose'. Other pins on the loaders are tight.
Wonder how long this becomes an 'oil war' ????
5,070
Tight.....loose......tight.....loose.....tight.....loose.....
3,323
The best thing in life is a loose, tight woman. 😜
