In need of a pic of regulator wire connector on the tractor side.
Jase556
B1750 hst
May 24, 2023
14
Nj
I have a b1750 I just picked up and the regulator was disconnected and the connector on the harness side is gone so there’s just 6 loose female 😀 connectors. I just picked up a connector kit and realized the wire colors on the harness aren’t the same as the rectifier. So a pic or description would be amazing!!
5,235
1,018
This should put you on the right track.
Jase556
B1750 hst
May 24, 2023
14
Nj
I’m not sure if this helps you any. I tried to pull it up to see if it would and had issues with it loading (likely on my end).
Thanks for the pics but I need the tractor/wiring harness side.
Jase556
B1750 hst
May 24, 2023
14
Nj
5,235
1,018
The first place to look for wiring diagrams for older B's is in the operators' manual not the WSM.
This is the wire color table.
The two blue wires come from the dynamo and they are interchangeable.
If this is still confusing ask more questions.
