The Glass
3,605
Assuming a "main bottle flow rate" of less than the flow rate of the tubes, my vote is 3.
2 and 4 don't get any until 3 gets filled.
The others are blocked
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
I think if you pour into the top glass faster than it drains to the other glasses you can fill glass 1 to over flowing before and other is filled.
Keep flow between the two outlets and glass 3 will overflow.
Work on this long enough and you will not notice that your 12 ounce beer is now only 11.2 ounces. Just over 330 ml
motionclone
May 4, 2018
1,399
996
Maine
7 gets full first
4,057
Who uses a glass when they drink beer anyway ? oh and it is 3
motionclone
May 4, 2018
1,399
996
Maine
3,215
None of them. Only one bottle supply is shown. If it was supplied by a beer tap rather than one bottle, , then glass #7…
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
And this is why I drink bourbon. It is way to darn expensive to play sophomoric games with.
Pour it and sip
JimDeL
Aug 31, 2022
360
401
Austintown, Ohio
7 can't ever fill. It's blocked off at 3.
3,215
Don’t think so. The lower part of the glass 1 outputs to glass 3. Glass 3 outputs to glass 7. Simple as that.
What am I missing? Granted no genius here… 🥴
Of course, it could be a trick question. The first glass to get fill is glass 1. Not filled, just fill.
Shame on you, DustyRusty!
JimDeL
Aug 31, 2022
360
401
Austintown, Ohio
The pipe to 7 is blocked at 3, so nothing will get to 7.
3,446
I keep thinking…. “What is WRONG with these ordinarily-fairly-sharp fellows…?? Can’t they see nothing is coming out of the beer bottle..?”
3,215
That‘s correct obviously. Missed that. With that in mind the answer is obviously glass six. 😁
In my defense, I will say that I live in a three dimensional world, and thought those tubes going to glasses 5 and 7 were connected on the back where they couldn’t be seen…🤣
JimDeL
Aug 31, 2022
360
401
Austintown, Ohio
No! Six is blocked at the bottom of the tube.
Sawdust&Shavings
Apr 25, 2023
97
85
Stafford, VA
None. I would consume the beer, while the rest of you struggle to agree on the correct glass.
Flintknapper
L2350DT
May 3, 2022
1,938
2,454
Deep East Texas
It appears that the correct answer can only be glass 3 or 4 since all others are 'blocked' in one location or another.
Since glass 3 is the first to receive fluid from glass 1.....it should fill first.
