Hi. Had a problem today that's driving me crazy. With the bucket curled almost all the way in, moving the stick to float does...nothing. This happens regardless of how high, or low, I have the FEL. Otherwise everything seems fine. Curled in somewhat less than all the way and everything is fine, float works. With the bucket curled in I can use the stick to move the FEL all the way down as usual. And, if I have the bucket most all the way curled in and float, while the FEL won't float by itself I find if I tap the stick left to curl the bucket out a little, the FEL will go into float. Not a big deal in truth but if experience has taught me anything it is that when things stop working as they should most often they get worse. Besides, it's driving me crazy. Thank you in advance.
