Anyone here own a boat, or know a lot about boats?
10,230
So, so true.
There are YouTube channels dedicated to covering all of the crazy stuff that happens at boat launches. One particular channel I watch occasionally is at Haulover Inlet in Florida. Amazing boats, some amazing women, and utter craziness getting in and out of that inlet.
10,230
Spare prop and composite prop wrench (and waterproof grease for prop)
Can you tell me if my thinking is skewed on this. The boat I bought has a very nice stainless steel propeller that appears to be in perfect condition. These propellers cost $700 to $900 it seems. Since the idea of having a spare propeller is to get the boat back to shore if something catastrophic happens, does it make sense to buy an aluminum propeller as a back up? Aluminum propellers are in the $220 price range.
If I were to damage the expensive propeller and get back to shore with a cheap one, I'd end up having to buy a new expensive propeller and would still need a spare. It makes sense to me to have something cheap as the spare. Does that make sense?
Freeheeler
b2650 tlb
Aug 16, 2018
706
527
Knoxville, TN
Yes, cheap spare is the way to go. If you prefer storing extra $$, just tape a few hundred dollar bills to the spare when you tuck it away. Personally, I don't carry a spare at all. If you check it before each outing, the chances of it falling off is pert near zero. Hitting a submerged log or such is much more likely and will damage the prop but very unlikely remove it. You can limp home (idle) with a damaged prop without hurting anything. If you hit something hard enough to knock the prop off, the spare will most likely not go back on anyway, you've got bigger problems.
6,384
yes, cheap spare. they make some that are actually composite. Only necessary if:
1) you run offshore (or very large lake)
2) you like to switch props based on usage (speed vs pulling)
3) you're a bubblehead and like to run aground (skeg usually takes the brunt of it)
4) yes, you can likely limp home on a mangled prop however, your day at the lake is over.
I had an extra alum 3 blade (also very light weight) that I carried on board (with a complete hub kit). The SS high-five prop I had covered both speed and pulling...easily.
Edit: I too have found myself watching that haul over channel on youtube (especially in winter months). Those guys are friggin nutz.
10,230
@Freeheeler & @dirtydeed, thanks very much. I've learned a lot from this thread and really appreciate all of the information. (y)
5,506
2,214
observe others. It's proven to be some of the best "free" entertainment I have ever seen. Enjoy. ;)
The only reason I ever go to the lake on any holiday weekend, is to watch the inexperienced try to make things happen. And of course watching the sheriff arrest and/or ticket the drunks and there are so many of those that there's not enough deputies to handle them all. Hence the reason you won't find me on the water on holiday weekends, period. I don't appreciate them while on the water. Not at all and there is no place I can go on that lake to get away from em. I can tie up to a barely submerged tree in an area where there are thousands more trees lurking just below the surface (and a bunch above as well) and it never fails some moron will try to water ski back there, or a wakeboard boat will halfheartedly try to ride the wake back there. A few years ago a jet ski came through there at about 60mph and hit one of those trees and capsized. Threw the operator about a hundred yards, he got hurt pretty good on that deal. I had to motor over there and assist righting the ski so he could get back to the ramp and go to the hospital. Left arm was definitely broken.
It is holiday weekends when you see a TON of idiots all in one place.
Look up "credit card captain"....and enjoy the show.
10,230
I picked up the boat this afternoon. The old F250 had no trouble pulling the load 65 miles back home. I should be able to get to the 300 hour engine service this long weekend. The rest of the order I placed will be here mid next week so I'm thinking a maiden voyage is less than 10 days away!
(y)
9,970
View attachment 103475 (y)
You really need to get a shop / storage shed built!
10,230
Tell me about it. I've started on a 30'x25' and once that's done I'll make something bigger. I certainly feel the pressure.
10,230
Will work, trade for guns! :ROFLMAO: :ROFLMAO: :ROFLMAO:
This morning I measured the height of the boat on the trailer and it's around 11ft. Looks like I'll be needing a 12' tall roll up door at some point. I found a brand new 10'x10' roll up door on Craigslist last year but that's slated for the 30'x25' shed.
B737
LX3310
Jun 9, 2019
2,022
2,205
Beautiful Robalo!
regarding spare prop, I would not bother. Spending $100 for SeaTow and/or BoatUS tow insurance per year is a lot safer and more effective.
The chances of successfully changing a prop while the boat is in the water are slim. Plus you will need a prop wrench with already tight storage space on a boat that small. If you drop any tool, or the thrust washer you are SOL.
9,970
I'm pretty sure that's not an option up here, your best bet is someone nice a friendly comes along and tow's you in.
B737
LX3310
Jun 9, 2019
2,022
2,205
they have coverage for lakes, dont know specific geographic details, ymmv
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
465
254
Randolph county N.C.
IMO, I did carry a used prop I purchased from the dealer that sold me the boat. I also had a prop puller, extra cotter pins, spare washer and spare prop nuts (I had a V-drive inboard). My reasoning was if I am a long way from home and spending several days camping, why let a dinged prop ruin the entire weekend.
Also props do come off without hitting anything. I served in the Coast Guard at a few search and rescue stations and have towed in several boats that lost propellers.
B737
LX3310
Jun 9, 2019
2,022
2,205
even if you spin the hub you should still be able to limp home, by design. Props normally dont just fall off (not saying it doesnt happen though, ive even heard of it locally as well)... that being said, im more interested in carrying an extra fuel water separator, extra fuel filter, strap wrench, fuses, some extra oil, ect... where there is a fairly good chance of something like contaminated fuel ect.
prop is pretty far down the list, just isnt worth sacrificing the storage room, the personal risk, for the very slim probability of occurrence. To cover all bases, add 5 feet and second engine : )
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,189
3,493
That's likely from human error. I've had carb problems, fuel pump problems, ECU and injector problems. Electronics, electrical, and water in the fuel....99 problems but a prop ain't one.
bird dogger
Vendor Member
Feb 24, 2019
1,752
1,727
North Dakota
Beautiful Robalo!
I have had to untangle ropes from lobster pots offshore (from this boat) and it's downright hazardous, wasnt even that rough out. Additionally, if the water temp is less than 65° going to add more complications.
Have AirChair, will travel................for a "pull" !! :ROFLMAO:
Not ready to trade it in for a rocking chair anytime soon!!
David
6,384
That was precisely my point. If you're a day-laker, then don't carry a spare.
One additional prop item I would add...is a decent prop lock if you over-night somewhere. SS props ain't cheap.
