ejb11235
BX23S, Braber BBR4G 4'BB & LRM5G 5' rake, Redline 48" rock bucket, PFL1242
Jan 20, 2022
486
374
Seattle, WA, USA
WoodMaxx WM-8H
I wanted a power feed , but I have no rear hydraulics. Not alot of hours on it. I've used it a dozen times. But works good. I'll get the blades sharpened this year.
This convinces me of something I've been wanting to do for a while ... I have a DR. Chipper with an 18HP engine. It's a towable model, but it would be super easy to unbolt the chipper itself from the trailer and mount it to a 3PT carryall so I can move it around with my tractor. I need to look at the Tractor Supply Carryalls, but there are several reviews with pictures showing them bent up. Options are limited in the Pacific Northwest. But man it would be so slick to tool around my property with the chipper on the back of my BX.
Trapper Bob
L4701, Wicked grapple, 7’ box blade, 6’ Wicked bucket, SVL 65-2 w/4 in 1 bucket
Jan 17, 2022
446
820
Andover, KS
The wife helped me plant the last 2 food plots today. Seemed like a waste to tear up perfectly good wheat, but we did.
My wife is a pretty good helper.
Reactions: 7 users
Flintknapper
L2350DT
May 3, 2022
2,024
2,579
Deep East Texas
View attachment 102849 View attachment 102850 View attachment 102851
Mighty good help there.
I know it seems a 'waste' to disc down a crop of wheat....but depending on what you planted it for, it is best to start a new crop IMO.
IF planted mainly for deer, they utilize wheat more before it matures, preferring the younger plant. But if planted also for Turkey, Quail...then yes, the food source and cover are temporarily lost.
In any case...the wildlife will enjoy the resource and benefit from your labor and expense. (y)
7,733
TB, thought you said you were short of rain! Doesn't look like it in that picture.
I like it when the woman has to be color coordinated while plowing in the back 40! ;)
She must have know you'd be taking pictures.
Trapper Bob
Jan 17, 2022
446
820
Andover, KS
The wheat was planted last fall with Austrian winter peas. These 2 crops will stay green & grow all winter, as long as the temperature is above 32 degrees. You are right, the deer love it. I have planted other crops, but this mix is my favorite.
Trapper Bob
Jan 17, 2022
446
820
Andover, KS
We have been getting some rain. Enough to keep things alive. We need to have some runoff.
We need to replenish our ground water. My creek starts in a hillside about 3/4 mile away & has not run since last June.
My wife works for Cabela’s. She sees all the cool gear & needs to try it out so she can tell all her customers about it. It makes her happy. She really likes driving the tractor.
7,031
Quick root infested sewer line repair. We were ready for the inspector by 10 am (he didn't show until noon).
Not much to this one at all. I was a bit concerned about the knee wall until I rolled up in there today. It didn't present a problem at all.
Removed large yew bush. Ready to dig.
Diggy:
Issue:
Repair:
Backfilling with the 36"
Done. Time to head home
Reactions: 6 users
radas
Mar 21, 2022
719
834
Had some tree work done today, once the stumps were ground, there were huge piles of dirt/chips. Since I am planning on adding topsoil later, I used the bucket on float to back drag the piles and pack the ruts in with the tires before it started pouring rain PXL_20230519_211643033.jpg . Much better for now 😁
radas
Mar 21, 2022
719
834
Diggy:
Issue:
Repair:
I'm thinking they should have paid to have that whole clay pipe replaced...lol
5,188
Diggy:
Issue:
Repair:
Easy.....
One 3' piece of Sked 80 and 2 FERNCO's.
dclauria
Kubota L4060HSTC, L4479 snowblower, EA 60" grapple, LP GS2584, LP BB2572
Jan 1, 2022
40
46
Northern Michigan
I had a friend cut down a 100' tall white pine that was over the pool deck I'm building. About 10 years ago half of the top came through our roof and closet ceiling. I've been resisting cutting it down but it was time. Now I have to clean it up.
5,188
Sawmill nearby ?
A shame to waste beautiful pine logs like that.
Gary Olson
L2501 w/FEL and grapple, 3pt auger
Mar 10, 2022
155
300
Mark Twain Forest
Oil change, filters change, grease all the zerks. Changing the HST filter pouring out 3 quarts of fluid is annoying.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,751
4,640
PEI Canada
Mowed 4 acres and headed to the next lawn and was missing a wheel off the mower. Went back amd found everything except the lynch pin and one spacer. Let's see if a piece of type L copper will hold up until I get parts.
