last year my tractor started making squealing noises on occasion when going over uneven ground. the propeller shaft tube that goes from mid pto drop to the front axle is smoking hot to the touch and does not look perfectly aligned . i want to pull the shaft to inspect. there is ( was) a roll pin that gets removed in order to slide a cover back over tube ( one of the roll pin holes has been broken off so the roll pin is not there) . im assuming the cover just slides back? looks like it might need some effort as it wont budge by hand.
thanks
thanks
