I have a 2000(ish) MX5000 2wd Kubota & I recently had to change out the control valve. After the swap, the 3pt has no power/lift strength at all. When the RPMs are maxed, it'll slowly raise, but won't lift any weight/load. Loader runs fines, power steering is good, & driving is good. I've been told too much fluid may have drained out (it took me about a week to do the swap due my schedule & weather) & that air may have gotten in over the piston. It was recommended to use the bleeder valve to purge the air out of the chamber... problem is, I'm not sure where the bleeder is or if this tractor even has one. I'm also not even sure this is the problem, although it seems rational to me. Any help or advice y'all can offer would be appreciated. Sorry for the long post!
