Drifthopper
2000 L3710 HST w/ Woods 1012 FEL. LandPride FDR2572, 60" Brush Hog: Need 60" BB
See pictures.
Brush Hog 5' / 60" rotary cutter with the top chain from back to the 3 pt arm.
Dad was using the brush hog some years ago, lifted it up, ( i don't know how he had the top link set ) the bolts on the slip clutch caught the chain and bent the bolts.
( and with his old Jimna china tractor, the shaft was too long for that 3 pt and pushed the gears out of the back of the gear box.... so that is why the plates & threaded rod are there surrounding the gear box... to keep everything together and inside..... buy.... hey.... it still works. )
I got my L3710 last spring and used this cutter as is, cut about 7-8 acres of our property.
The area that I cut last spring / summer was already cut a few years ago, so other then some heavy brush, it was " easy " cutting. I didn't hit anything hard.
Now...... I want to expand what area we want to keep open.
And cut some areas that have not been cut in a very long time.
So..... what i'm asking... from what is pictured.... Do you guys think this slip clutch will still " slip" ....?
Are they Re-build-able..?
I don't want to be cutting an area that hasn't been cut before and hit something hard, and this thing does not slip and it takes out the PTO in my tractor.
