b5001E Stuck in neutral
BERLINERBEER
Kubota B5001e
Hi All, My B5001E is stuck in neutral. The Pto will not turn, Changing from hi to low also hasn't changed anything.
I have managed to get the tractor out of the field using the bucket to nudge along backward so the wheels are turning freely.
My question : where do I start interms of ruling things out. At the time it stopped working there was NOT a big bang/clunk etc. I was mowing using flail implement and had just reversed and went to move forwards again. Hydraulics are working fine.
Any guidance greatly apreciated.
3,147
I suspect the shifting fork may have come loose or out of position.
Does it feel like it is shifting and just not or does it feel different than before? I would try to lift the top cover of the transmission case and see if you can see if it looks okay. I think if you lift it too high it will get disconnected but then you can see if anything looks off and then reinstall the cover and shiftin forks
11,237
Clutch is cooked, or you have damaged / broken the input shaft.
I say this because you have neither movement of PTO function.
If it was a shifting fork issue, you would still have PTO function. ;)
BERLINERBEER
Kubota B5001e
Great thanks for the Pointers, Just managed to recover the tractor to our Garage. So next step is pulling things apart. Haynes Manual is en route so once its here I'm gunna make a start
BERLINERBEER
Kubota B5001e
Feels same as Before, thanks for posting
billrigsby
Mar 17, 2015
1,064
278
Florissant CO USA 8213'
www.facebook.com
So I have split the tractor at the gearbox end! here's what I have discovered.
Now What next? I don't even know what to call the shaft that's broken.Any help greatly appreciated.
Neither is from an exact manual for your tractor, but similar.....
From a B7000 Parts Manual
From a B5000, B7000 Parts Manual
Hope this helps a little.
11,237
Ouch, that's some serious damage!
It's very possible that something else is jammed up or broken to make it twist a shaft like that.
