Land Pride 1260 bushhog gearbox
DonDon
L2501
Jan 30, 2018
12
Brandon, ms
Time to get things ready for the summer and noticed my gearbox is loose. I need to tighten the 4 bolts up. Looks like I need to take the stump jump off but I’ll be darned if I can find the size of the socket I need to take that bolt off.
Vigo
B6100, B8200
Jan 9, 2022
595
342
San Antonio Texas
Hold a tape measure to it. Or slide calipers. Or, if you dont mind half-assing it to get it done in a hurry, just stick a pipe wrench on it and smack that with a hammer. But im guessing you own a tape measure so that wont be necessary 😂
4,638
I have never taken a stump jumper off, and never tightened the gear box;
If I remember correctly there is supposed to be a hole to access the bolt/s that hold it on from the top for the blades, but here's a video that kind of explains removing it. Its about the 2 minute mark. (and it don't sound fun)
Paul
MOOTS
MX6000
Jun 27, 2019
2,189
2,718
Canton, Georgia
Looks like there were 2 different gearboxes used. One is M24 and other is showing 1” or 1 1/4” for the nut. The 14 could be the pitch though. Good luck.
Vigo
B6100, B8200
Jan 9, 2022
595
342
San Antonio Texas
Those look like thread measurements. 24mm is slightly thinner than 1”.
Some tow balls have a 1” 14tpi shank, and use a 1-1/2” nut. If that happens to be the size you need you might be in luck because all kinds of places sell ‘tow ball wrenches’ for $8-15. Harbor Freight, Walmart, Autozone, etc etc. Its just a huge double box end wrench with 1-1/8 and 1-1/2 ends. If it fits put it on there and smack the end of it with a 3-4lb hand sledge, or put a big cheater pipe on it, and you might be in business. Of course 1-1/2” sockets do exist but they’d often be in 3/4” drive size and not many people have 3/4” drive tools. You can get an adapter but a lot of 1/2” drive anvils will snap before they move a rusty 1-1/2” nut. I would only use a 1/2” impact on a nut that size, not a 1/2” ratchet or breaker bar. 🤷‍♂️
MOOTS
MX6000
Jun 27, 2019
2,189
2,718
Canton, Georgia
I think you may be right. Those are the thread measurements. If so, the OP should get about a 32-36mm and the inch equivalent and go from there.
@DonDon go to harbor freight or the equivalent, buy a handful of large sockets, return the ones that don’t fit.
