5,066
Cleaned up an Elm yesterday that died off last year. 28x34 on the stump. Firewood will keep my dad warm this winter.
Lots of good stove/fireplace wood, but elm is nasty chit to split.
Siesta Sundance
Oct 23, 2022
1,554
1,945
youtube.com
View attachment 100814 View attachment 100815
Managed to sneak this heavy SOB into the garage. The LX barely lifted it with the forks from the heavy side so I slid it out of the trailer and then turned it around and slid it into one of the garage bays for now until my power beyond pipe shows up next week. I used two 3 ton jacks to maneuver it once it was in the garage.
I also got a screaming deal on an open box OTC 1500lb tire dolly on eBay for $150 so I'm going to play it safe and use the dolly to remove the loaded tires so I don't end up with a situation where my kid comes around and tips the tire over.
Sweet!
S-G-R
LX3310
Jun 17, 2020
1,116
2,264
PEI Canada
Waiting for the drum to fill with water then rolling the lawn.
pokey1416
Jun 24, 2020
556
825
SW Michigan
Picked another bucket of rocks this morning before the rain came in.
mcmxi
6,336
NW Montana
Nice field! There are some amazing rock/stone picking machines out there. I have four big piles of rocks on this property that someone cleared (by hand I assume) many years ago, but more come to the surface over the winter. Some are boulders that stick out of the ground and will never be moved.
mcmxi
6,336
NW Montana
That is a nice roller. How much does it weigh when full of water, and what is that structure to the right that stands about 4ft tall? Never mind, your follow up photo makes it clear.
johnjk
Apr 13, 2017
1,462
1,271
West Mansfield, OH
Driveway round 2. Thanks NCL4701 for the tip getting it smooth with the box blade was a breeze. Just need more weight on it. Got rock coming next week to top dress and play some more. Will compact that with a roller once done.
radas
Mar 21, 2022
719
833
Broke down and installed the swivel seat... Kubota Parts wanted almost $900 for the BH77 fixed seat (pretty much the price of the subframe). The swivel seat must have been redesigned - while it sits higher, it doesn't lean forward like others have mentioned.
S-G-R
LX3310
Jun 17, 2020
1,116
2,264
PEI Canada
I've seen those used here. All we have is sandstone and not much bigger than what you had in your bucket.
S-G-R
LX3310
Jun 17, 2020
1,116
2,264
PEI Canada
It's 4' across and 3' tall. I'll let you gogglefu for weight😉 a friend built it to use with his four wheeler so it's a good foot narrower than the tractor. I looked at a couple of pull types and if I go that route I'd have one made as the commercial versions seem flimsy. Del Morino make a three point version but big bucks to get one here although I haven't ruled it out.
radas
Mar 21, 2022
719
833
Uncrated the BH77 - @Fordtech86 you were right, what a PITA.
Removed the 3pt from the Tractor
Installed the longer joysticks - this was an even bigger PITA. 3 heim fittings for each joystick with very little room to get a wrench on them and tighten the supplied bolts.
g_man
Feb 3, 2023
156
708
NE Vermont
Water service today. No big deal with the exception of my stupidity...
Start:
done:
evidence of my haste/stupidity:
I dropped the tailgate right off the truck! Luckily another Kubota was within reach for me to pick it and place it back on the truck. :p
Did that once - like you said, talk about feeling stupid. Luckily no one was looking.
gg
3,680
Friday, sewer line turned into a fiasco. Turns out that the building had a perimeter drain the I had to dig next to. Created quite a mess. We finished at 9:45 pm in the dark. It turned out well (from what I could see with the lights in the mini). Didn't get a whole lot of pics because we were in a hurry to complete the job before rain was coming.
Very impressed with the U-27. It was able to pick a very large chunk of concrete and loaded on the dump truck. I wasn't sure it would work, but it did...it struggled but accomplished the task. Very powerful little machine.
Perimeter drain issue:
3,680
Saturday post excavation cleanup with the other Orange machine...
before:
After:
Done for the week now. 4 jobs and I'm beat. On my second T&T as I type. :p
3,680
Broke down and installed the swivel seat... Kubota Parts wanted almost $900 for the BH77 fixed seat (pretty much the price of the subframe). The swivel seat must have been redesigned - while it sits higher, it doesn't lean forward like others have mentioned. View attachment 100831
awesome.
Now fab up one of these to make it easy to roll around in your garage. let me know if you're looking for street pads for the hoe.
street pads:
2,548
