Thanks for the reply. The tractor had been sitting for about 8 was. I found that the last user (my sonj ran it out of fuel. I knew that I would have to bleed the system. There was evidence of water at the water separator bowl. I drained the tank and I added clean fuel and I started at the water seperator, then the lines to the injector pump, then the injector pump. No joy. I had fuel at the pump intake fitting, but none at the lines going to the injectors. I placed an electric fuel pump in the line leading to the injection pump. I applied fuel under pressure to injector pump. Still no fuel thru the pump. Any ideas. My next thought was clogged injector pump, I shudder at the thought of fiddling with the pump, I know next to nothing about how to rebuild one. Any ideas appreciated.Start with the basics and go from there
1). Does it have fuel in the tank?
2) Does the fuel run out of the hose into the fuel injection pump? You can remove the hose to see or crack open the bleed valve on the injection pump. I prefer the hose since it is a bit more flow and is easier to tell if it’s flowing properly.
3) If not there, then where do you get any fuel flow from (into the fuel filter)?
4) If nothing is getting to the filter then loosen the fuel filler cap (don’t remove completely) and blow low compression air into the hose and back into the tank? Be prepared to catch the fuel in something or get it back onto the filter as quickly as you can. It may s to gush out if the clog is blown out of the line or the tank outlet.
Tell us more about what has been going on with the tractor, what did it do and when was the last time it was used? Was this sudden or has it been sitting for months or years?
Assuming that “8 was” really means ”8 weeks” and the water separator did its job (well) would b encouraging to me that the pump has not been damage. But there is still some concern for the pump.… been sitting for about 8 was. I found that the last user (my sonj ran it out of fuel. I knew that I would have to bleed the system. There was evidence of water at the water separator bowl. …
Thanks, that’s something to look forward to. Always wanted to rebuild an injectshon pump.If it had water in the injection pump and sat for a length of time and the rack is stuck, you're more than likely going to need a new pump, no rebuild is going to fix it.
So solly No Speke Melican.Assuming that “8 was” really means ”8 weeks” and the water separator did its job (well) would b encouraging to me that the pump has not been damage. But there is still some concern for the pump.
Was the screen in the separator in good condition and is “8 was” some typo so you can tell us in a time unit that we understand or are you one of the lizard people aliens?
