Bearcatrp
Mar 28, 2023
1,031
646
Minnesota
Found a 2 inch gouge in the side wall. Debating on putting a tube in it or replacing it.
Took tire off and brought it to a tire repair place. figured I would check on the possibility of a big patch and a tube. Nope. Too big of cut. Dealer called today to tell me it’s cheaper to buy the tire and rim than just the tire. Ordered it. Will be here next week. I’ll put the rim away in case I bend one in the future.
MOOTS
MX6000
Jun 27, 2019
2,189
2,716
Canton, Georgia
See if anyone in your area does vulcanizing.
fj40dave
Sep 24, 2009
425
257
Yelm, WA
Is this the one? https://www.harborfreight.com/65-hp-plate-compactor-69738.html
i have been thinking about renting one but I have a lot of landscaping I would like to do the next few years so not sure if I should rent or buy. I imagine if it’s held up for you using it on the job for a while it will be more than enough for me.
View attachment 100682 View attachment 100682
This is the one I use.
They work great on the gravel with the minus in it. The surface is really firm after using it.
The plate is 17" wide.
I welded on four corner hooks and made a sling so I can move it with the tractor bucket.
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
Small tractor so small logs. Big heart in that little tractor.
Two dead trees at the bottom of the drive. Wife said they gotta go. A controlled drop verse nature making a mess.
Yes, I drag them with the 3pt . I know it is frowned upon. Lifted just enough so as not to snag in to the ground and bring me ass over tea kettle coming up the hill. Hand on the throttle and foot just resting on the clutch. Keen eye on the fronts to make sure they are not loosing traction and starting to come up.
Reactions: 8 users
5,181
I don't particularly see that as a safety issue, with the heavy plow (or loader bucket) way out in front.
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
I don't particularly see that a safety issue, with the heavy plow (or loader bucket) way out in front.
I agree. The geek in me did the math and in theory the 800 pound tractor with a 400 pound plow frame under and out front, 250 pounds in the seat, a couple hundred pounds of wood and a percent of that on the hitch. This should be as solid as it gets.
The little guy in the back of my head who has heard of all the old stories of relatives and co-workers that tipped or flipped and I tend to get very paranoid on the hill.
My R1's tend to dig in and spin before anything bad happens. Of course stopping half way up the hill and sitting in the seat trying to think of how do I get out of this mess is never fun.
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
I LOVE IT ! ! ! I hauled trees like that (and larger) for ~15yrs with my TG1860 garden tractor until I bought the BX. Nothing wrong with it afaik
MOOTS
MX6000
Jun 27, 2019
2,189
2,716
Canton, Georgia
Is it really a good idea to do a sidewall vulcanize repair?
Probably.
Not that it matters, but I’ve seen off-road trail rig tires vulcanized, and absolutely beat down with 700+ hp rigs hold up fine. Think 20+ mph and hitting a rock ledge and jumping to the next… beat downs. Also partaken in sewing a hole closed with wire and stuffing in as many plugs as it took to stop the leak, that held all weekend.
Is it the best case scenario, of course not.
Flintknapper
L2350DT
May 3, 2022
1,991
2,518
Deep East Texas
The 'Little Tractor that Could'....! Excellent. (y)
They may be small (mine is a compact) but they can push or pull a surprising amount of weight.
Don't lift much....but will push/skid things around just fine.
Reactions: 8 users
dieselbob69
Kubota BX2380 (previously a BX1870 and GR2100)...
Jan 2, 2022
159
61
WNY
Wishing the dealer would let me effing know wtf is going on with it, dropped it off 4/1. On the 14th I stopped by and they "just" got it into shop and were looking at the saddle arms. KTAC in the meantime has forwarded me a first and second request letter :mad: :mad: :mad: ....
radas
Mar 21, 2022
719
834
Front tire was really low for some reason, filled it. Checked and filled the rest of them too. Filled rears were messy even with the valve at 12 o'clock (I didn't have the rear wheels in the air). 32psi in the front, 28 in the rear.
Mounted the BB on the Pats quick hitch in preparation for "moving" my BH77 crate off of the trailer tomorrow. Between the hydraulic top link, Pats, and Box Blade cart I made, took all of 2 mins to connect everything.
radas
Mar 21, 2022
719
834
+1, sidewall repairs are a no-no. I don't know about tractors, but tire shops won't ever repair a sidewall on a car/truck.
jyoutz
Jan 14, 2019
3,442
2,532
Edgewood, New Mexico
I removed my heavy rear blade and installed my Fred Cain plow. It’s time to move from snow removal to garden preparation.
Trustable
l2501HST
Jul 5, 2022
215
146
Ripped and smoothed 500ft driveway with the box blade today. I’m not doing area in front of garage due to how it looked after doing it last year. Took about 1.5 hours. I really need some stone but I can at least keep it kinda smooth in the meantime. Used riding mower to compact after, as it is gonna rain today so figured a light compaction would help.
Reactions: 9 users
Old_Paint
Dec 5, 2020
1,929
2,095
AL
Spent nearly 6 hours on the LX today mulching a large natural flower bed and undoing a mess I started nearly 20 years ago. Cleaned out a bunch of old punk and debris from a wash that goes across the property with the grapple. I've been dumping all the leaf waste and limbs and non-firewood trees in it just trying to keep it from eroding any more. SO, basically I cleaned up a mess in an afternoon that took me 20 years to make. Picked out the larger unrotted chunks and piled them farther back in the lot, and just raked the rotted stuff down to blend it with the soil. There were night crawler worms in that stuff that looked like small snakes. The soil under that stuff is fantastic after all the years of composting leaves, grass clippings, and anything I couldn't give to someone to burn in their fireplace.
My grapple is one built for/by LS tractors, model MCG-1154A. Not a heavy duty grapple at all, but it's doing everything I ask of it. It'll hold more than my LX can pick up. I moved two 14 foot logs from a tree with a 30 inch stump, so I'm not complaining. Bent the outside tines on the clamshell four times today while picking up heavier logs (which this grapple CLEARLY is not designed for). It normally happened when I grabbed something sort of end on and it twisted out of the grapple with the tine embedded. So when I knocked off for the day, I welded gussets on each tine to prevent them from bending again. I looked one time, and the right most tooth was pointed straight out to the right. Beat it back with a hammer each time, and decided if I was gonna be so rough with it, I better improve it before I broke it. Used 1" x 1/4" bar stock to make the gussets. Rubbed a little more paint off with a flapper wheel and used my little cheap wire welder to put 'em on. Not a professional looking weld job by any stretch of the imagination, but it'll keep the teeth from bending. Got the top jaw done, and may do the bottom as well, but the tines aren't as long as the top ones and they don't tend to bend as easily.
Reactions: 6 users
