Time to test the Toothbar
JeremyBX2200
BX2200
Aug 3, 2020
506
455
Indiana
Time to test this guy out. Bought it over the winter and just installed it today. We are expanding the garden and I want to remove the sod prior to spreading a bunch more topsoil and compost.
Reactions: 6 users
7,323
Jeremy - - I liked the easily removable feature of the Piranha toothbar, but it's never been taken off. Always on the bucket. I think you'll really like it. (y)
Bmyers
May 27, 2019
3,625
4,910
Southern Illinois
That makes two of us. Once I put it on, I haven't removed it.
JeremyBX2200
BX2200
Aug 3, 2020
506
455
Indiana
I am going to be spreading about 20 tons of top spoil in a few weeks. Interested to see if it makes it easier to get full buckets from the pile.
3,056
After 10 years - I have never taken it off either.
On thing to notice - if you are digging into a bank or trying to dig into the ground - engage the edge and wiggle the toothbar up and down - this will drive it in and make it easier to break off a good chunk of dirt!
Bmyers
May 27, 2019
3,625
4,910
Southern Illinois
Just one word of advice, be careful walking around your bucket. Those edges can hurt when you run into them not paying attention. Nothing like firsthand experience to learn from.
Reactions: 7 users
Bmyers
May 27, 2019
3,625
4,910
Southern Illinois
Duplicate (fat fingers)
JeremyBX2200
BX2200
Aug 3, 2020
506
455
Indiana
I have heard this before.
I believe some people use a piece of 2" pvc with a slit cut in it to cover the tooth bar when the tractor is not in use. I will probably do something like this
bbxlr8
Mar 29, 2021
455
314
Eastern PA
Mine hasn't been off in 2 years either.
BTW - One whack on the ankle and you won't forget ever again - ask me how I know as well :p
cthomas
LX2610 HSDC
Jan 1, 2017
865
576
La Farge Wi
Installed that bar on both tractors, neither has ever been off. I have learned to bury the bar in the ground when it is not in use(I was slow and hit my ankles a few times)
Smokeydog
Jun 2, 2020
757
729
knoxville, Tennessee
BXPANDED is a local company. Made a custom weld in repair toothbar for skidsteer bucket for the M59. What really improves function on a low Hp tractor makes a big difference with a little more hp behind it. Clearing brush nothing is faster. V-teeth pull stuff out of the ground a grapple has troubles with. Can’t beat grapple for carrying. This time year best for clearing. Believe a toothbar is one the best, biggest difference and cheapest attachments you can get. Enjoy.
DVR
Kubota MX5400, L3560LE, L3301. KX033-4
May 8, 2020
122
68
Columbia, SC
I've seen other posts suggesting ways to mitigate damage while parked. A cover if you use the bucket for utility (fertilizer bags, tools...) could be helpful. I happen to have another identical bucket with a smooth edge and just switch buckets or tractors.
So, I just curl the bucket down and allow the bar to sit on the ground. There is no way for it to hurt someone like that. The bar is robust and that has not seemed to have any impact on performance. YMMV
7,323
I just leave my bucket flat/level to the floor such that the teeth don’t catch anything…got snagged couple times myself. Seemed to be the better option.
Dave Ogren
BX23S w/FEL &BH &60" Mowing Deck, 48" Dirty Dog Box Blade, 48" Tar River Tiller,
Feb 16, 2022
100
47
Asheville, N. C.
I just got mine Tuesday and installed it. I am really happy with it. Makes a real difference in the ability to scoop easier good size loads. Thanks BX.
mrmurph1965
L3901HST, LA525 Loader,
Oct 5, 2021
17
NWMissouri
I'd really be interested to hear how this did removing sod. I have one and love it, I generally use for removing small saplings and such. Does a fine job of that.
5,187
I do not have a tooth bar quite like that, but it would not "bury" easily in my concrete floor.
7,623
An easy way to protect yourself and others from the sharp edges is to cut off the required length of 4" drain pipe and cut it in a straight line length wise. Open the cut edge and slip over the dangerous part.
5,517
I aint got one,,,, yet,,, but I have heard they are right up there with bumper hitches
