Hello all. I am attempting to fix the front PTO shaft that drives a belly mower. The owner got fed up with the shear pin snapping everytime he hit something so welded the shaft up. The result is that the shaft broke and is now lost. I have scoured the web to find diagrams or pictures but I still have no idea what it originally looked like or which bits have been modified. I would very much appreciate it if anyone has any diagrams or pictures that would relate to the model I am working on and any advice as to what to do and where to obtain any parts required. The clutch shaft that goes back to the engine should have splines on it where it enters the UJ but they are all worn off. From the UJ to the flange on the end of the crankshaft the shaft is missing. The flange also looks as if it may have been altered. I will try to add some pictures. Thanking you in anticipation of your help. Bernie
