3 point repair L2250
PMore
L2250 with a Woods loader
Dec 22, 2022
11
Wilming il
I have been trying to get my 3 point arms working again. Replaced all the hydraulic fluid and filter. Also, have replaced the hydraulic pump, and the arms still don't work. Any suggestions would be appreciated. Love my old girl and summer is just around the corner... Thanks
5,187
Have you considered replacing the teflon piston ring on the lift cylinder piston ?
11,022
Does it have a loader on it?
There is a selector valve (slotted head shaft) on the side of hydraulic block just under the fuel filter housing, any chance you could give us a picture of that?
Is the three point feed back linkage attached?
Has it been checked for adjustment?
Have you observed the shaft going into the case move with movement of the position control?
Do you have the WSM (aka service manual)?
If not just ask! ;)
PMore
Dec 22, 2022
11
Wilming il
No I haven't our local dealer just talked about changing the oil, and the pump I replaced on my own.
PMore
Dec 22, 2022
11
Wilming il
It does have a loader but it currently off, and I will take a picture tomorrow.
11,022
BINGO, Yahtzee, Par... enough games to the rat mobile!
Almost guarantee you the selector valve is in the wrong position!
3,079
deleted post
others asking same questions while I was typing (and eating supper)
PMore
Dec 22, 2022
11
Wilming il
11,022
Sorry it took so long for this pictures
The last picture you put up, in the center of that block is the valve.
turn the selector to match the red circle.
PMore
Dec 22, 2022
11
Wilming il
I will give that a try tonight it would have been nice if the dealer told me about this by pass. Luckly this has been a year I didn't need her to plow the snow. But this Will be tried before the rebuilt bucket is going back on. Thanks!!!
PMore
Dec 22, 2022
11
Wilming il
Thank you, Thank you, Thank you I own this machine for 10 years never had the bucket off. Bucket started leaking real bad last summer, so getting ready for winter dropped the mowing deck, dropped the bucket off to rebuild the cylinders seals. And have been pulling my hair out since last year.......
Thanks again
  • Dislike
