BX1500D wont crank
joesmith123
L295DT, BX1500
Mar 18, 2023
532
140
earth
Here's a video of what its doing
Maybe one of the levers is in a position where it doesn't allow cranking if its engaged?
please help
joesmith123
L295DT, BX1500
Mar 18, 2023
532
140
earth
All the fuses are fine
The sensor line does not have current at the starter (little wire that tells it to crank)
5,236
1,018
please help
I am providing the starting circuit wiring diagram showing you there are 4 safety switches in the circuit from the key switch to the starter.
The first place to check would be the seat which has two switches.
To prove the starter itself is OK you could "jump it." This has a serious risk as you are bypassing all safety features. My suggestion is to have someone in the seat with a foot on the brake.
Use a piece of wire or even an old screw driver to bridge the small terminal to the terminal with the battery cable. Expect a few sparks. The engine should crank instantly if the starter is OK.
joesmith123
L295DT, BX1500
Mar 18, 2023
532
140
earth
Is it in neutral? I take Venmo and Paypal. 😁
I had no clue how to put this thing in gear, after i read your comment, I went and read the manual
Then I messed with the levers, and I must've put it in neutral,
boom, started right up, runs like new
Whats your venmo? I'll send you $15 since I had to figure out the levers
joesmith123
L295DT, BX1500
Mar 18, 2023
532
140
earth
Thanks
Thanks for the data, definitely useful info, but it turned that maybe the machine was in gear and when i got it out of gear, it started right up
2,968
How about me? I had the answer but forgot to post it...will PayPal work? $5 will be fine...LOL
joesmith123
L295DT, BX1500
Mar 18, 2023
532
140
earth
Stay tuned, I will be paying lots of $ for solutions because I have no clue what I am doing, but can fix stuff long as you guys give me direction
6,394
Get working on the L295, I need to pay off my truck loan!
joesmith123
L295DT, BX1500
Mar 18, 2023
532
140
earth
The bx1500D, I am not seeing a hydraulic fluid reservoir, it will take about 2.7 gallons of "UHD" which goes into the big transmission under the seat
It will run a bucket using this fluid? I am not seeing a hydraulic reservoir on the front
orangeisgold
BX1800
Apr 10, 2023
NC USA
Not necessary. Glad to help!
6,394
Yes one sump (reservoir) runs everything.
