I am providing the starting circuit wiring diagram showing you there are 4 safety switches in the circuit from the key switch to the starter.
The first place to check would be the seat which has two switches.
To prove the starter itself is OK you could "jump it." This has a serious risk as you are bypassing all safety features. My suggestion is to have someone in the seat with a foot on the brake.
Use a piece of wire or even an old screw driver to bridge the small terminal to the terminal with the battery cable. Expect a few sparks. The engine should crank instantly if the starter is OK.
