I wouldn't. Rear MotorTrend's assessment of towing with the Gladiator...they are, or at least can be, pretty unstable with a heavy load. There are also a number of them with broken or bent rear frame sections from towing, within the rated amount, but off-road. The Gladiator has a couple of things against it as a tow vehicle - there is considerably hang-over of the frame and bed past the rear axle, relative to some other midsize like a Tacoma, Ranger, Colorado, etc. This is so Jeep can try to have a reasonable ramp breakover angle for off-road, as well as keep commonality with the front portion of the Wrangler JL frame. There is quite a bit of lever action on the Gladiator's hitch hanging back so far from the rear axle. Finally, unlike all other midsize and half ton trucks, the Gladiator has a solid front axle with slightly wandering steering, and coil springs at the rear which can be softer and "squishier" than the normal leafs.
It's worth noting the diesel is very powerful and is rated to tow over 10k in the RAM 1500 pickup with the same engine. However, the smaller Jeep grille and engine bay limits cooling, along with a smaller, weaker frame compared to the half ton lower the tow rating here. Both the gas V6 and diesel have an excellent 8-speed transmission made by ZF. I'll also point out the only Jeep Gladiator to get the 7,000lb tow rating is a specific model - a Sport with the Max Tow package. This is a basic trim model, which may be a problem for some people.
Don't get me wrong - I love the Gladiator and Wrangler, in fact, I own a 2022 Gladiator Overland (with a 6k tow capacity) but I would not try to tow more than 5k with it.
thanks for the reply!! i generally lean towards a bit of over kill, i never over load anything. maybe i will get the GF a 2 door to rip around in and get myself a proper truck.
![20230409_124143[1].jpg 20230409_124143[1].jpg](https://www.orangetractortalks.com/forums/data/attachments/99/99957-fa6b897b19ba83a138b297a2081cb766.jpg)
![20230410_191919[1].jpg 20230410_191919[1].jpg](https://www.orangetractortalks.com/forums/data/attachments/99/99958-07c7c537be138bb00439ef321676e1bd.jpg)
