Or a leaky lift cylinder.What can cause the 3 point hitch to bounce when not down.
We do believe he's talking about it bouncing with no input or external movement, it's just doing it on it's own.Don't they always bounce? They have upward pressure, not downward pressure. So you can always lift the lift arms by hand - I guess unless it's all the way up, but even then I suspect there's still a bit of play.
When lifting a box blade the hunting almost becomes violent.Don't they always bounce? They have upward pressure, not downward pressure. So you can always lift the lift arms by hand - I guess unless it's all the way up, but even then I suspect there's still a bit of play.
How long will the 3pt hold a raised implement after you shut off the tractor?When lifting a box blade the hunting almost becomes violent.
Ah. So almost like it's still trying to lift even when it's at desired height? Or is the upper stop not set correctly, so it's still trying to go up when it's already reached the top? Diagnosis would be different between those two. Video would be super useful.We do believe he's talking about it bouncing with no input or external movement, it's just doing it on it's own.
The 3pt hitch drifts down at whatever speed is set on the speed valve under the seat. It raises normally and begins to shake when raising action is stopped. Actually everything works normally when the down speed is closed except it won't go down of course.How long will the 3pt hold a raised implement after you shut off the tractor?
The 3pt hitch drifts down at whatever speed is set on the speed valve under the seat. It raises normally and begins to shake when raising action is stopped. Actually everything works normally when the down speed is closed except it won't go down of course.We do believe he's talking about it bouncing with no input or external movement, it's just doing it on it's own.
So thats not drift down. Drift down is when the lift wont hold a raised load. If you raise a load and turn the trsctor off does the raised load remain at the set point or does it slowly drop?The 3pt hitch drifts down at whatever speed is set on the speed valve under the seat. It raises normally and begins to shake when raising action is stopped. Actually everything works normally when the down speed is closed except it won't go down of course.
I'm sticking with Feed back linkage is mal adjusted!The 3pt hitch drifts down at whatever speed is set on the speed valve under the seat. It raises normally and begins to shake when raising action is stopped. Actually everything works normally when the down speed is closed except it won't go down of course.
I copied the required page but am having difficulty loosening the the front nut. Is in a bad location. Also noticed the position control only starts raising when the control is near maximum height. Could the feedback arm just fall out of adjustment? It's not been touched since 1986.I'm sticking with Feed back linkage is mal adjusted!
Do you have the WSM (aka service manual) to adjust it?
If not just ask!
At top of lift the position control is what stops the lift from trying to go too far. Is posiyion conyrol moving when the lift is at mid point and bouncing?I copied the required page but am having difficulty loosening the the front nut. Is in a bad location. Also noticed the position control only starts raising when the control is near maximum height. Could the feedback arm just fall out of adjustment? It's not been touched since 1986.
I'll try to check that when I feel a little better. Thanks.At top of lift the position control is what stops the lift from trying to go too far. Is posiyion conyrol moving when the lift is at mid point and bouncing?
Yes it bounces along with the hitch . I tried raising the hitch and killing the engine. It does drift down. Not fast but down in a matter of seconds. When I say control is moving I don't mean the handle. I mean the feedback rod.At top of lift the position control is what stops the lift from trying to go too far. Is posiyion conyrol moving when the lift is at mid point and bouncing?
That sounds like something in the lift circuit is leaking at a prettty good rate. What happens is:Yes it bounces along with the hitch . I tried raising the hitch and killing the engine. It does drift down. Not fast but down in a matter of seconds. When I say control is moving I don't mean the handle. I mean the feedback rod.
Thanks Dan,That sounds like something in the lift circuit is leaking at a prettty good rate. What happens is:
Does that match what you are seeing?
- You raise the position control lever to the desired height and the lift raises until the control valve goes to neutral when the selected height is reached,
- With the control valve in neutral the lift is supposed to hold there but because something is leaking the lift starts to drift downward
- The feedback system sees the drift and opens the control valve to restore the lift to the set point.
- This drift and restore process simply repeats and repeats as the circuit continues to leak and the feedback system corrects to maintain the set point. The faster the leak the faster the lift oscillates.
The lowering speed valve closes off the hydraulic circuit between the lift cylinder and the position control valve.Thanks Dan,
I see what you mean. How does the manual control valve under the seat work into that? It holds the load up when closed.
