A (better?) alternate to Rim Guard tire ballast- (Edit -really bad idea!)
Otis H.
MX5400
Mar 30, 2023
9
Sebastopol, CA
Edit: looking a bit deeper into the notion described below, I concluded that there is really no way to use preservatives to prevent spontaneous fermentation of simple sugars, wnich you definitely don’t want happening in your tractor tires! Chalk one up for Rim Guard, which I’ll be making the drive and paying the price for now;).
I was intrigued by the idea of putting 600# of beet juice, an eco-friendly waste by-product of sugar beet processing, in each of the rear industrial tires on my new MX5400. That plus the 1000# 3-point ballast box I have should do the trick for balancing out a full loader. I found the nearest source to be a 5-hour round trip to Placerville , CA, and was quoted a price of $6/gallon(gulp!)
researching alternatives, I stumbled upon the water/sugar mix that beekeepers make for getting bees through the winter, which weighs exactly the same 11#/gallon as Rim Guard. I determined that the 650# of fully refined sugar from the local WalMart I’d need to make 100 gallons of that solution would result in a net cost of just $4.16/gallon, and save me the 5 hour drive to boot!- Otis
kubotafreak
Sep 20, 2018
1,049
398
Arkansas, US
Cast weight if you ask me. I dont like rotted rims. Plus no loss from a tire puncture, and easier to work on… but for the weight you cant beat it. Rims are pretty much not powder coated in the drop center.
Otis H.
MX5400
Mar 30, 2023
9
Sebastopol, CA
Agreed, but sugar water is really not corrosive in this context. That is why they call the beet juice product Rim Guard. salt solutions used in the past did have this problem. As an extra safeguard, I have a method insuring that the non-liquid space is either 100%Nitrogen or 100%Argon, both of which I have on hand as a wine maker. Oxygen is required for corrosion even with the salts, but this is overkill protection with the sugars.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,437
1,732
Kalamazoo, MI
How much did you pay for the new MX5400? I'm guessing north of $30k. My favorite analogy is the guy who bought a new Nikon SLR camera outfit and then complained about paying $3 a roll for film (back in the late 1900's when cameras used stuff called 'film').
5,181
"Beet Juice" will not freeze in cold climates.
Sugar water will freeze.
I do understand that freezing is not likely in Placerville CA.
old and tired
L2800 HST; 2005; R4
I'll just say that I had a front tire on a lawn mower explode - best guess was it started to ferment or bacteria started to grow in the green Slime. I saw the tire earlier in the day and noted that it was over pressurized - was going to look at it the next day.
Middle of the night, VERY LOUD explosion.... the wall and underside of the deck looked like a version of Ghost Busters' slime.
Otis H.
MX5400
Mar 30, 2023
9
Sebastopol, CA
you’ve got a point for really cold climates. this solution would have a freezing point well below that of plain water, probably in the low 20’s°F. A bit of methanol would take it lower. Most tractors around here in Sonoma County, including my current 45hp LS, have plain water in the wheels. It is just 8#/gallon though.
Otis H.
MX5400
Mar 30, 2023
9
Sebastopol, CA
Touché! I’ve not made a firm decision yet and may still go for the Rim Guard. It is a combination of hassle and cost that’s got me looking for alternatives. I do prefer liquid ballast to wheel weights, though, partly for the lower center of gravity effect and, in the 11#/gallon range, twice the weight of a triple set of Kabota weights.
5,181
8.33 lbs/gal. to be exact.
5,817
so.. curious... haw many beets does a farmer have to harvest to make 600# of juice ??
also since water is 2/3rd the weight of beet juice, that'd be 400# of water, install 1 or 2 wheel weights to make up the difference ??
Otis H.
MX5400
Mar 30, 2023
9
Sebastopol, CA
BINGO! See edit of my original post.
jyoutz
Jan 14, 2019
3,441
2,530
Edgewood, New Mexico
Check into bio-ballast. Non corrosive, doesn’t freeze, and less messy than rim guard.
Henry E
B2710
Mar 19, 2023
Grass Valley CA
Who in Placerville does the rim guard?
Staggerlee1976
LX2610, LA535 w/54"QA, LP 60" Box Scraper
May 28, 2023
12
24
Petaluma, CA
I realize this thread is old, Otis, but what did the local Kubota dealer propose filling them with? I'm just over the hill from you in Bloomfield/West Petaluma, and I was planning on approaching them about options. Like you, I am loathe to haul the tractor two plus hours for beet juice, and I don't think dealers here in CA are going to want to/ be able to dispose of that much alcohol solution or windshield washer fluid when the time eventually comes.
5,817
I 'dispose' of used WW fluid in my truck. Use is year round. Still have gallons of it on the shelf...probably a lifetime supply. Used 3-4 gallons of it when cleaning out the fuel tank of the BX years ago...
