Little Help?
Ripp
B6200HST
Mar 6, 2023
30
Pennsylvania
Can someone help me out? Not sure my FEL control is hooked up right. Part # is 27fabs6m1ab and the “in” line is hooked opposite the PB port. Not in the IN port.
Backstory; my 3pth moves when operate the FEL. Can’t seem to figure out why.
3,245
1,868
The in should come from the pump discharge.
The pb should go to the 3ph valve.
The out should return to the transmission case.
Sounds like you may have a couple swapped. Does the FEL work ok?
kubotafreak
Sep 20, 2018
1,049
395
Arkansas, US
Sounds like the 3 point is being fed by the return to tank not pb.
Ripp
B6200HST
Mar 6, 2023
30
Pennsylvania
The fel works fine. Both the in and PB go to a box, with a lever on it, attached to the side of the block. I turn that lever to the left and the fel doesn’t operate R side the in. L side is hooked to the PB. From there the pb line becomes metal and goes all the way back to the 3ph.
