Will I break the transmission by running chains on rear tires in 4x4?
Mitigator
Kubota B2650, snowblower, back blade, rake, Heavy Hitch,
Feb 23, 2023
I'm new to tractors and I'm running a front mount snowblower, chains on rear tires and rather than keep the diff. locked, I'm using the 4X4. I have a B2650 with hydrostatic transmission. I just watched a youtube video of a guy named GP in Canada that said his dealer told him he can't use chains and 4x4 at the same time as it will destroy the transmission. Any validity to this?
Steve67
B2601-fel, 60"mmm, 5' rear blade, balast box
Jan 20, 2017
354
141
St. Louis, mo.
I have used chains and 4x4 in snow over the years and it’s never been a problem
Mitigator
Feb 23, 2023
NO !
the dealer is an IDIOT, his picture needs to be in the dictionary next to the word IDIOT
Thank You! Made absolutely no sense to me. But this is my first tractor and thought it might be an odd tractor thing.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,818
2,241
Western MT
I've only used mine for 2 seasons. No breakage so far. I also have front chains. I think you'll be good as long as you do it when traction allows for some slipping, and aren't cutting the wheels tight over and over.
That being said, there probably isn't reason to keep it in 4x4 if you don't think you need it.
nbryan
Jan 3, 2019
1,377
907
Hadashville, Manitoba, Canada
From your post it seemed to me it was a choice of diif lock OR 4x4, not using both together.
I run 4x4 almost all winter having no pavement here and ground frozen solid, for whatever I'm using the tractor for including snow blowing. No chains.
In 4x4 often need the diff lock engaged at the same time for that little added grab on slippery or rough ground. Like sometimes the snow blower tries to push through a deep stiff snow bank and the wheels start spinning at a standstill, I engage the diff lock and away we go.
I have never had a problem using the diff lock in 2x4 or 4x4. Just not on "sticky" ground to avoid driveshaft binding up.
MINICUP28
B7610, KX-018, RTV-500, JD X758
Feb 21, 2019
104
54
COBLESKILL, NY
17 YEARS NOW ON THIS TRACTOR AND NO PROBLEMS YET. LONG STRAIGHT DOWNHILL GRAVEL ROAD.
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
Except for the last two years my 1986 has always run chains on the rears in the winter and muddy spring. I have watched the rears and fronts do some wild spinning while plowing in 4WD and it is still doing just fine.
10,200
Rear only chains, no issues.
Front only chains, your flirting with disaster!
ve9aa
Apr 11, 2021
1,193
972
NB, Canada
BX2380.
In 4WD 90% of the time.
REar tires are chained. 100% of the time.
MMM & front blower
Summer, winter, whatever.
Only when I know I'll be on tarmac or doing long runs on my hard packed gravel driveway, do I take it out of 4WD
3rd year - no issues.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
937
915
E.
Why would front only chains be flirting with disaster?
in slippery situations makes smaller front end take the majority of the work load / stresses versus design of front assisting in work load and back end taking majority of work load..
Kubota designed the B's with front ends significantly smaller (weaker) than the larger/stronger rear ends. So they designed gearing and tire circumferences accordingly.
Slippery conditions with chains on front only has rear end doing little load (slipping) so front end ends up taking most of the stresses which it was never designed to do.
same reason why changing the ratio of front/rear tire circumferences is also dangerous.
Grandad4
Apr 5, 2016
408
159
Greensboro, NC
Great explanation that also relates to the questions many new owners have regarding the need for ample rear ballast, especially with front loaders.
hoobie
mx5100
Aug 11, 2020
14
canada
I agree although many will disagree. I run aggressive studded rear chains on my mx5100 all winter in my snow plowing and logging operations. My dealer warns against front chains especially in my usage where fronts could get strong bites on roots etc. They have seen front damage because of this before.
MapleLeafFarmer
Dec 2, 2019
937
915
E.
agree... bad things happen all the time when people don't pay attention or just don't know better. I no longer have my commercial skidder but it too was chained all the time.
If rear chained tires were spinning operator needs to let up on the throttle cause if front chained tires all of a sudden catch on a root, etc.... often a very loud "SNAP" quickly follows.
Those guys we used to call un-employable. Any spinning wheel is a break waiting to happen. Add chains to a spinning wheel and a break is sure to happen. Roots under bog was the worst.
mine looked something like this. HUGE front and back axles but still fronts are weaker cause of CV joints and operating angles.
