Wiring lights to battery help
mtnplower
Kubota L5740
Jul 15, 2022
71
Sierra Nevadas
I'm trying to install lights that have to be wired directly to the battery.
I tried removing the positive battery post but the nut doesn't come loose.
Does anyone have advice on how to wire lights up to it?
RMS
LX2610HSDC, RCR1260, PFL1242, LX2963, RB1684, WC-68,Flail Mower,Grapple, Z421
Sep 26, 2021
220
409
Buckfield Maine
Not sure about the wiring piece,but I would get the battery nut on your terminal taken care of. At some point you will need to take that connection apart and I can just about guarantee that it will not be at a convenient time or place.
BobInSD
L5740
Jun 23, 2020
361
123
South Dakota
I would suggest a fuse in there, as close to the battery as possible. At least a fusible link if you need a lot of juice.
I agree with RMS--take the terminal off now in a warm barn with lights, not "later" in a cold, dark, wet, windy place.
That said, I'd go to the alternator end of that same wire if adding "stuff". There's probably a lug there you can just slide a circular terminal on. (Obviously, then I would put the fuse as close to that as possible).
2,551
Get the battery terminal/cable fixed btw!
You need a relay hooked straight to the battery - that way it is on a separate fused circuit and you could have the lights on with the tractor off on those rare occasions.
this is simple install - you can get the relay and ALL the way almost anywhere - here is one source
https://www.amazon.com/Wiring-Harne..._1_6?keywords=Relay+Kit&qid=1675906449&sr=8-6
i7win7
Feb 21, 2020
3,379
3,982
Central, IL
Additional info on adding electrical devices
bird dogger
Vendor Member
Feb 24, 2019
1,601
1,459
North Dakota
A proper fitting box end wrench should get that clamp nut loose. There's also battery clamp pullers made just for removing the clamp to prevent damaging the battery post itself or its internal connections.
2,817
Not a Battery Terminal puller (but commonly mistaken as one)
