Shifter levers leaking hydraulic fluid from the boots where they enter the transmission.
mstracka
Kubota L2202DT, 60 inch wide Meteor snowblower
Mar 30, 2022
Hayward, Wisconsin
Tractor is an L2202 DT (grey market, approx. 1960-1970 vintage). 3 cyl. diesel. Question is: Can the cover that the shifter levers go through be removed safely such that the seals can be replaced? Is this a relatively easy repair and reassembly?
kubotafreak
Sep 20, 2018
1,049
397
Arkansas, US
Make sure the gear case housing vent is not obstructed. As far as the boot/seal they are replaceable, finding the correct part # will be the larger chore.
This is off a l2350dt for close reference
5,257
1,046
Have you verified the transmission oil level.
Water getting in thru leaking shifter seals can raise the fluid level.
Water sits on the bottom of the transmission producing a high oil level sitting on top of the water.
Your machine does not look like it sits outside but have you used a pressure washer on it.
9,111
Make sure the vent, normally located under / around / near the seat, is clear.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
678
288
Herald Calif.
As others have said check oil level be sure not over full. Most likely the vent is plugged and nothing wrong with the seals in the shift levers. Vent should be under the seat on the left side. Looks like a question mark.
mstracka
Mar 30, 2022
Hayward, Wisconsin
I am having trouble finding that vent, but I will keep looking. Thank you for the response.
mstracka
Mar 30, 2022
Hayward, Wisconsin
This is off a l2350dt for close reference View attachment 95135
Thank you, Dave.
mstracka
Mar 30, 2022
Hayward, Wisconsin
Thank you for the response. I truly appreciate it.
kubotafreak
Sep 20, 2018
1,049
397
Arkansas, US
Generally, it is located with a rubber candy cane in one of these two spots under the seat.
Dirt daubers like to clog the tube. Usually I take them off roll them in between your fingers to break up the blockage, and blow a little compressed air in them.
Orange4X4
L2350DT with loader , 52" Taylor Way , Ratchet Rake , Land Pride post hole
Aug 12, 2018
42
Concordia, MO
I have a L2350dt and the vent got dry and broke off. I put a clear poly hose on the cap where the orange one was. I also have issues with water leaking into the trans and raising the level. Parking under cover now.
