No, house full of company all weekend. Blower is on agenda for today.You have confirmed what I already learned by diagnosing the problem with the actual snowblower.
By the looks of the weather it could be weeks before the blower moves any snow. My base is gone and we are in the mud season here. It looks like the end of March. I don’t blow any snow until we have driven over and packed down, and it has to get COLD.No, house full of company all weekend. Blower is on agenda for today.
That is correct. The angle of the blower has no effect on this coupling. The front blower assembly is solidly fastened to the assembly that contains the coupling. These two components are then raised and lowered as a single unit via the hydraulic cylinders. The universal joint on the shaft takes care of the difference in angle. The shaft also telescopes and has to be kept lubricated. If this shaft is not able to freely slide it could possibly contribute to wear to the coupling.It turns out hard to get pictures/videos with the geometry of this thing and how close to the ground it is. If I can get a chance soon I'll drive it up on some auto ramps and get the evidence. But from what I can tell, I am not so sure the 'angle of engagement' changes when you lift or lower the hitch. The hitch has two u-joints in it, and the angle of those DO change. The coupling set between the blower and the hitch seems to engage at a perfectly straight angle at all times.
Dusty, I totally agree with everything that you have stated to diagnose this issue. Just trying to imagine what other forces might be causing the rear half of the coupling to not properly engage the front half and cause wear. I just can't understand the logic in having a metal-on-metal contact and expecting it not to wear. Makes me think of someone trying to use a boston coupling without the rubber insert. If I find that this starts to be a re-occurring issue with my blower and Kubota does nothing to correct it, I will be looking for another means of attachment.I explained what happens when you raise the snowblower and how the two parts spread apart. I showed the pictures, and I stand by my original explanation. You have to remove the 4 cover bolts to see this, which isn't that difficult.
It is spring-loaded, but it is a powerful spring, and I doubt that it is moving because of the spring. I believe that it is the two plates that are separating as you raise the blower. The blower on my machine will raise 12", and that is why I installed the block to limit that to only 6 inches. I am going to experiment in a few weeks when I am healed and able to do work in the garage again to try to limit the movement to 3".I'm trying to 'see' what's happening using the BX2810 install sheet and have a
question...
Does the 'engagement lever' actually 'lock' into a notch to KEEP the 'tractor side of the clutch' engaged to the blower clutch piece ? Looking at the drawings, like Figure #14, it looks like just 'over center' and spring tension keeps the mechanism 'engaged'.
If that's true( springs only, NO retaining notch ) then it's quite possible it may move backwards due to, um,gee... vibrations ?, or PTO on/off cycles.
It'd be a simple test, with safety cover off, raise blower up and try to move the 'engagement handle' backwards, seeing how much force is needed. Maybe bang it a few times to simulate 'plowing into a barrier' ?
I'm kinda wishing I had one on my BX23S but.....all I have is RAIN to deal with......and I don't need to blow $5K+ ? on a 'science project' so 2nd best that I can do is offer 'long distance support'.
The Allen set screw on the male coupling keyway was loose. That is the only thing that was off. Do you think that could have been the problem? I do not see how that could be an issue. The bolts keepUpdate, I finally got to the blower. Winter left and we had a lot going on in the last three weeks.
Here are some picks of couplings, new and old. It has not left garage yet but probably will today.
I am nervous to be honest.
