Looking for diverter setup for L35.
Bill K
2000 L35, BT900 BH, Woodmax chipper, Titan forks, Kubota grapple
Oct 16, 2021
Foster, RI
It appears as if no one has anything in stock for L35. Tractor Data has listed as 17gpm and everything looks to be 13gpm. I have a forestry plan in motion on twenty acres and really need a grapple on the machine.
10,984
You don't need all 17GPM for the third function as some is for the PS.
The loader is 11.1 GPM.
5,187
"Foster" ????
R.I. ???
Have you tried both MB tractor (MA & NH) and Messick's (PA)?
Coleman's too (MO).
Bill K
Oct 16, 2021
Foster, RI
"Foster" ????
R.I. ???
Coleman's too (MO).
I have been on phone and computer most of the day looking. Messick's has been my go to but they said three weeks, "maybe". Afraid to go with a 13GPM because I think I will lose too much power.
10,984
Did you read what I wrote?
Bill K
Oct 16, 2021
Foster, RI
Yes and correct me if I’m wrong but my bucket functions would also be reduced to 13 gpm due to the diverter? I don’t really know how much power I would lose on the lifting arms.
10,984
You only have 11.1gpm for the loader to use.
So putting a 13gpm third function valve in is not going to reduce any flow to the loader at all.
The other 6.12GPM is on a different loop, that loop runs the Steering, Three Point and the GST.
And fyi GPM is not power, its speed, PSI is power.
Bill K
Oct 16, 2021
Foster, RI
Well you just made my life easier:) Thanks for the info
10,984
Diverter for grapple
Do you know the operational difference between a diverter and a third function?
For those that don't know the difference:
A diverter uses the lines that operate the tilt cylinders, and diverts them to the grapple cylinders to open and close.
A third function valve adds another circuit to the loader that operates the grapple.
The real advantage of a third function is you can tilt and grapple at the same time, and not just one or the other.
If you are using a diverter, than none of the GPM conversation matters as your not using 11.1 gpm on tilting the loader bucket, your using like 2 to 3 gpm if that!
Bill K
Oct 16, 2021
Foster, RI
Thank you for the info. I am aware of the difference but for the cost of a third function I did not see that much of an advantage and yes, I have ran all types of equipment during my career in the construction industry. I'm just not real familiar with the mechanics of hydraulics.
5,187
My diverter operates through the third function, and is used. for SSQA locking.
10,984
It's really worth the extra $ when it comes to ease / functionality of grapple operation having a third function valve over a diverter valve.
10,984
That an excellent use of a diverter valve because it's not a constant under operation use, more of a lock it and forget it operation.
5,187
The machine came to me (used) with that feature.
It works especially great for this old guy too, because it eliminates the need to dismount, for locking/unlocking.
7,203
I would not expect much difference in cost. You still need the joy stick handle with switch and that is crazy expensive at almost $200.
Bill K
Oct 16, 2021
Foster, RI
Using a diverter kit from Summit and making hoses locally I am at a hair over $520, kits from WR Long or Summit for PB run around $900
7,203
You have obviously made your choice and the diverter will work fine. You actually lose very little functionality using a diverter given the operation of Kubota loader valves.
But you can roll your own "true" 3rd function for much less than $900.
  1. A generic D03 solenoid valve with manifold is $200.
  2. A joystick handle with harness is $185 from Summit.
At that point you are at $390 and 90% of the way there. The remainder is the same hoses, fittings, couplers, and brackets you need for a diverter.
3,828
2,384
Or, if you have fab capability and value your time at $0/hr, you could do something like this
