Kubota d722. No throttle after front engine cover was replaced
Gman58
Kubota D 722 (Jacobsen gp400 triplex mower)
Jan 24, 2023
Foster city California
Hello, I recently replaced the front engine cover on my Jacobsen gp-400 with a kubota D722-EF03 engine. After removing and reassembling the front cover, installing new throttle and stop solenoid springs, water pump Ect. Now the the engine starts up quickly and idles nicely, but there is no throttle, won’t raise up more than idle. Confirmed springs are connected, just no rpm when the throttle lever is raised to full throttle?. Anybody have a clue what I’m missing?. Nothing simple like a throttle cable not connected. Thanks in advance for any advice!
Rusty46
B7500 HSD-R, LA 302, RCK60-24B, Woods RB-72, Millcreek 25, Harrow, Payne PF800,
Not familiar with your machine, but I experienced loss of throttle control on my B7500. The throttle lever moved easily with little to no resistance. I found a spring clip had fallen out of the linkage from the lever to the engine. Mine took a M1.2 clip. I hope your problem is as simple to fix.
8,679
Did you remove the injection pump?
Gman58
Jan 24, 2023
Hi, no, I didn’t need to remove the injection pump to remove/replace the front engine cover. Only had to transfer the governor/throttle, pulley, water pump and the the adjustable pin that I’m pointing to in the picture. Is this for the governor/throttle adjustment by chance?.thank you!
8,679
Yes that sets either max fuel or max RPM's I would have to look in the WSM and get back to you.
8,679
Is the front pin bottomed out?
If so, back it off about half way and try it again.
