RBsingl
Jul 1, 2022
485
566
Central IL
It hit 52 degrees yesterday afternoon so the F2690 got a light break in mostly chopping up some leaves that hung around from last fall. It had .9 hours from dealer prep and delivery so I only put another .7 on it and then used the Stihl blower to clean everything up before it went back into its garage.
The treadle pedal is going to take some getting used to going between the F2690 and my Deere 955 compact utility.
Rodger
trueg50
60
78
Vermont
Rodger View attachment 93870 View attachment 93871
That machine looks like a blast, I can't blame you for wanting to get right out and use it. Heck, if I had one I'd be using it to run down to get the mail at the mailbox everyday.
GrumpyFarmer
4,667
That’s a great machine you got there. 🤤. If the snow is light and not too deep it would do a respectacle job to clear the drive. Laugh if you want but MMM on a small tractor do just fine with light snow.
RBsingl
Jul 1, 2022
485
566
Central IL
It is definitely going to be faster for mowing than my Deere 955 when Spring arrives AFTER I get fully used to the different handling and technique with the Kubota front mount. I expect the cut will be better since the deck will be ahead of heavy parts unlike my Deere 955 with midmount deck.
Rodger
RBsingl
Jul 1, 2022
485
566
Central IL
The Deere 955 will keep its snow removal duties but now I won't have to pull the loader off of it for mowing which will be convenient! There are a few area where the Deere 955 may be the finish mower of choice with its wide wheel spacing to provide best stability but for most of my 5 acres the F2690 is going to be perfect.
Rodger
MOOTS
MX6000
Jun 27, 2019
2,189
2,718
Canton, Georgia
Rodger View attachment 93895
I disagree. You will get uncomfortable, before that F mower thinks of lifting a wheel.
RBsingl
Jul 1, 2022
485
566
Central IL
Matt,
I should have explained better where the 955 will have the advantage. There is a fairly long area of a roadside ditch with an unusual slope that is best cut with the tractor straddling the ditch and the wheel spacing gives the Deere with midmount deck an advantage here. And now that I have the F2690 as the primary finish mowing tractor, I can set the 955 rear wheels to the wide position which will make it even better for that situation. In the past I have kept the rear wheels in the narrow position so that the 6' deck better covers the width of the tractor with a little margin.
I suspect the Deere will be doing at most 1% of the finish mowing now :) Even with just a few minutes to get used to the different controls and handling of the F2690, it is obviously going to be faster and more relaxing to use. That seat is amazingly comfortable also.
I am sure I will soon be looking at my Kubota F2690 purchase the same way I look at the diesel standby generator I installed a few years ago in that now I wonder why I didn't do it a LONG time ago.
Rodger
beelzebubba
B26 TLB, Land Pride STB1072, Titan pallet forks
Dec 20, 2022
11
55
Vast New England wilderness
Helped my sump pump contractor haul bags of concrete and sacks of gravel from his truck around to the bulkhead entrance to the basement. Beginning to get a feel for FEL balance and driving and saved his guys a ton of toil schlepping that stuff.
ve9aa
Apr 11, 2021
1,193
972
NB, Canada
Snowblowed 12-16" (depending on where on the property you were)_ of very heavy wet drifted (27-28") snow.
Out by the road the snow completely filled the blower. The snow was drifted up to and over the bumpers of both cars.
Broke a shear pin about 2 minutes before I was all done.
(always the way, right? 2 minutes in, or almost done...heh heh)
Pin did its job. I was snowblowing a wee bit too close to my rear blade which is parked on the corner of a parking lot and just barely clipped it. Pa-TING !~ I knew it as soon as it happened.
Shucks!
Reactions: 6 users
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
No snow, nothing on the to do list, plenty of time on my hands.
Tractor has been sitting so I fired it up just to keep everything lubed and ready if needed,
Should be ice fishing but there ain't no ice.
Tried to load video but it just looped a black screen.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,563
3,865
PEI Canada
Thought I was going to have snow to blow when I got home this afternoon but rain took care of that. We're probably going to be green again tomorrow. Definitely not the usual weather for eastern Canada.
GreX
BX2380
Jan 8, 2023
185
132
Maine
Sounds exactly like what is happening down here in Maine, very odd weather, even today we got more rain, freezing rain, and a bit of snow, with a bit more rain.. no white stuff on the ground, even on the grass.
Also, I love PEI, such a cool place!
On topic - I did add the BXpanded Under Armor to my BX, seems well built and easy to install. For those of you that do have this on your tractor, and use a rear mounted snowblower, or other rear mounted PTO driven things, is there a way to lock the plate in the up position? I have the cutting length set to the highest setting, allowing it to sit a few inches below the frame, but it'd be nice if there was a way to keep it in the up (top) position?
pokey1416
Jun 24, 2020
569
868
SW Michigan
Cleaned out the zerk cups and torqued roof bolts, after taking top off a couple months ago. Found 3/9 needed torqued to spec’s.
JimDeL
Aug 31, 2022
414
467
Austintown, Ohio
There's one setting beyond the "0" on the knob, marked "T". That should keep the skid plate in the uppermost position.
GreX
BX2380
Jan 8, 2023
185
132
Maine
I tried doing this, watched a video where the guy said to raise the PTO's up which would allow it to go into higher settings, but I can't seem to get it into the zero (0) setting, which I believe is the 'Top" on the mower knob.
S-G-R
Jun 17, 2020
1,563
3,865
PEI Canada
Same here today, tomorrow and then warming up and rain again.
