mdhughes
L3901DT
Dec 10, 2014
1,396
1,271
Ste Geneveive county, MO
Did some firewood yesterday. Fell another blonded Ash tree, cut it in 60" logs and used the grapple to move them to the firewood area. I was a little surprised when I was able to pick 3 of the logs up at once. When I got off the tractor to get a picture, I was really surprised at the one log. Not sure what was keeping it on the grapple. Went about 1/4 of a mile in the woods with it.
Reactions: 10 users
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,543
3,794
PEI Canada
That's definitely a mouthful👍
Trapper Bob
Jan 17, 2022
446
818
Andover, KS
I have a decision to make. Do I burn this in the stove or put it in the pond (that is being cleaned out now) & catch crappie over it. What do you think?
Gary Olson
L2501 w/FEL and grapple, 3pt auger
Mar 10, 2022
149
286
Mark Twain Forest
Cut down a couple of trees. The ground was still soft from the rain a couple days ago. Learned a new method for almost tipping the tractor over; and a couple new ways to get bogged down. Left half the trees for pulling out in the summer when the ground is dry and solid.
S-G-R
Jun 17, 2020
1,543
3,794
PEI Canada
It's nice to learn a lesson and still keep it upright.
edritchey
2021 Ferris IS800Z - 2025 New Holland WM75
Jul 19, 2014
1,137
852
Wellsville, PA
Got the little tractor ready for snow :giggle:
Not much snow here yet but I'm sure it's coming...
GrumpyFarmer
4,526
Yesterday afternoon I used the M to drag an elk carcass up into the woods to feed the birds and beasts. I also moved a bunch of bark to the burn pile and got ready to cut up some downed trees that should burn well. The snow was over 2ft deep in places and no way that the MX would have made it the 1/2 mile or more I had to go. The M is a tank and had no trouble in some fairly deep snow and hilly terrain.
Is that a Jet Sled? What size is the sled?
Old_Paint
Dec 5, 2020
1,944
2,130
AL
As wood goes, Ash isn't real heavy or dense. Not to mention, it's SUPER easy to split. Seems sometimes all you have to do is say something mean to it. If that were green hickory or white oak, I'm not sure the LA525 would have lifted three logs that size. Those are about 250 pounds each, just guessing, if not a little lighter. Hickory would have been at least double that weight. This late in winter, most of the sap would be down in the roots on ash. You probably still had a little weight margin on that loader, depending on the weight of the grapple, but diameter got ya. That's definitely a mouthful. It is satisfying to move that much weight/material with a relatively small tractor in a single trip. I could get two of those with my little grapple, but it won't open wide enough for all 3. I don't need (nor want) to move that much firewood, so mine serves its purpose. What is that, the EA Wicked?
10,028
It's an Otter branded sled sold by the local Murdoch's farm/supply store. I have a couple and this is the bigger one. They've proven to be very useful for firewood, and in the summer they cover up pieces of equipment such as the front hydraulic snow blade to keep the sun off.
L35
Jun 13, 2010
643
709
CT
Moved some logs around. Broke 1200hrs on the meter today as well.
Reactions: 11 users
mdhughes
L3901DT
Dec 10, 2014
1,396
1,271
No, the logs weren't really that heavy.
It is a Homestead 55″ Root Grapple Pinnacle Series and I think it weighs right at 300 pounds.
10,028
Back to blowing and pushing snow around this morning with the MX. Running the engine at 2,200 rpm with the PTO engaged to drive the snow blower rather than 2,700 rpm is really making a difference with fuel consumption, a big difference.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,158
3,422
Beautiful day so I went out to check the tire on the B3200. Flat again and lots of bubbles around the rim. Took it off and will get it to the local tire store to have it dismounted, cleaned and sealed.
More concerning is the puddle of antifreeze under the B1700. Looks like a core leak in the right front corner. Plastic tanks on it as well. Called my local dealer and had to sit down. New rad is 2100.00. Gonna do some research and see what the aftermarket has. Bummed but I have time before the grass starts growing.
$2100?!?!? OMG!
7,207
I can get a new unit with brass tanks aftermarket for 800. I know I have to have some welding done on the mmm, no big deal there but in the back of my mind, what’s next. I think I will pull it and take it in to the local radiator shop to see if it is fixable and the cost. Coolant is only down a small bit and no active drips. I’ll get her back in the attached garage with my tools and pull it out.
I had a note I just found. Might check out "1800 Radiator" 877-819-1800 . They can build what you need and very reasonable priced and they ship.
johnjk
Apr 13, 2017
1,705
1,938
West Mansfield, OH
Now that I have the tire/rim issue resolved on the B3200 I have it parked back away from the door so I can drive the 1700 up to the garage to pull the radiator and get it to a local shop. If they can repair it we go that route, if not I’ll look in to these other options a bit more. Having it out will also let me measure and take pictures to help with either cross referencing or building a replacement. Thanks everyone for the tips.
On a side note I want to test that radiator fluid as well. I doubt it has ever been changed. Does anyone do a radiator fluid check and change as part of their. Maintenance schedule?
