There are plenty of places to get a plate. This one was less than $200 when I bought mine and its perfect.I will be stopping in this week to see about the plate, I think they will guarantee it to fit they have a good reputation. I do have a welder and torches.
When I bought my tractor I ask how much a plate was salesman quoted me $200 I don't know if is a Kubota part or not.
Thanks for the info Mark
Good deal.View attachment 93511 View attachment 93512 Picked up the plate today. The main plate is 3/16” steel. $130
I did not ask about the plate from the dealer, didn't know there were differences at the time.How thick was the plate from the Kubota dealer going to be???
It will be fine for most uses. You just need to be sure you distribute the load across it. Weld dont bolt the implement to it and use gussets or stiffning ribs as appropriate to the implement.I did not ask about the plate from the dealer, didn't know there were differences at the time.
Dan,It will be fine for most uses. You just need to be sure you distribute the load across it. Weld dont bolt the implement to it and use gussets or stiffening ribs as appropriate to the implement.
The slots the pins drop into are also a potential weak point. If its going to see really heavy loads there beef them up.
Great! Hope to see some pics soon!The plate has 3/8" plate on the top and bottom. As for 3/16" being to light I was just looking at the bucket and it is mostly 3/16' plate with 3/8" top, bottom and along the sides. I will be welding a snow plow to it and will add plates to spread the stress. Hope to work on it this weekend and will share pictures.
I think running a chain from the top of the SSQA plate to the plow frame would be a good idea.View attachment 93606 View attachment 93607 View attachment 93608
There ready for the snow. The steel that goes almost all the way across the plate is 2x2” solid steel that the plow is welded to. I do most of my plowing with the back blade and mostly just pile the snow with the front plow.
