Hello there!
So as per the title I will explain the stupidity that has happened. We had a guy doing demo in a building taking block walls down with a buster on my Kubota KX008-3 excavator with a D722 engine. Long story short operator error caused the guy to tip the machine completely on its side. To make matters worse it did not shut off and the operator left it running on its side for roughly 2-4 minutes before getting it upright again. The machine was shut down after because the operator complained about “poor performance” afterwards. Well I looked at it the next day and immediately upon starting it, it non stop rough idles and blows a very thick white-ish smoke out of the exhaust. Coolant level is good doesn’t bubble in the coolant bottle but I am at a loss. Is there something that would be likely to happen to cause that smoke after running on its side? Also to be sure I am including all the information the same guy was caught draining the fuel tank on the ground. When asked what the Fu#% he was doing he fessed up and said he accidentally put gasoline in instead of diesel. Since I was not there at the time another guy said he made sure to drain it completely. The tipping incident happened the same day. I’m sure this sounds like a stupid question, I hope I am posting in the correct space I just figured I would give this a try. A side note that “operator” has since been fired seeing that he completely failed on the smallest cheapest machine we own and was absolutely not worth the risk. Any information someone could possibly provide would be greatly greatly appreciated. Thanks in advance!
