CNC rubber mats for my L2501 HST
mdhughes
L3901DT
Dec 10, 2014
1,383
1,197
Ste Geneveive county, MO
I really like the mats, but I have found a small problem with having them on my L3901DT, you really have to push down hard on the clutch pedal when you engage the PTO. Not a big problem, just have to remember to do it. From what I can tell, the rubber on the peddle is hitting the floor mat.
In case someone reading this doesn't know, the L3901DT has a two stage clutch.
gatrs4u
Kubota L3700SU HSTLandPride RCR1860 Rotary Cutter Rhino Finishing Mower 60" Quic
Jun 30, 2022
Middle TN
I would like to know if these would fit on my L3700SU
5,184
Noice. You cut those on the CNC? You wouldn't happen to have a drawing/model you'd be willing to share, would you?
I don't have a CNC, but I do have access to a plotter, I could print out a 1:1 and try my best at cutting/drilling by hand.
I'm a little worried about sand/moisture getting underneath there and rotting the floorboard away, but at the same time, it's not as permanent (read, "easier to back out of") as going the rhino lining way.
The mats look great!
The problem is that sand/grit builds up underneath, and when wet, promotes rust.
I threw my OEM mats away, and applied Herculiner instead.
MountainMeadows
Jun 6, 2022
219
289
Poconos, PA
The new floor mats for the L3302 also fit the L2501.
HST part numbers
No code has to be inserted here.
TeachercoachMT
Jan 1, 2023
Roberts, MT
I want to take a moment and thank all who have purchased mats and I have enjoyed the conversations we have had! I continue to offer mats for some of the L-series HST and now include some of the L-series DT models. After searching Messick’s & Kubota’s website here is a list of compatible models I found. There may be other compatible models that I didn’t search. The mats are easy to install and remove for cleaning no hardware needed. Send me a PM if interested. Thanks
HST Mats for Models (RH Pan Prt# TC420-57483)
L2501, L3301, L3901, L3200 (serial# > 84376), L3800 (serial# > 84931
DT Mats for Models (RH Pan Prt# TC420-29900
L2501D, L2501F, L3200Dt, L3200F, L3800Dt, L3800F
DT Mats for Models (New):
L3301DT (RH Pan# TC620-29902)
L3301F (RH Pan# TC620-29902)
L3901DT (RH Pan# TC620-29902)
L3901F (RH Pan# TC620-29902)
View attachment 62462 View attachment 62463 View attachment 62464 View attachment 62465 View attachment 62466
How can I purchase the mats for my my 2501?
Paul Speer
L3400 HST, LA463, Land Pride 1860
Jun 10, 2023
Vancouver, WA
My first forum. I shared these on someone else’s existing forum but not sure that was the correct way. I made some rubber mats for my L2501 HST. They should fit other L series HST models if interested. Easy to install and remove for cleaning.
I am looking for mats for my Kubota L3400HST and unable to find them from any usual sources. Do you make them for this model?
Hawk67
2020 L2501 HST
Dec 18, 2020
South Carolina
Hey Paul,
I sent you a private message thru this form. I will check and see if I have that style captured in a design.
Thanks,
Ken
