Hi all,
I have a BX2200 and need to replace the front motor mount bushings (or that is what I would call them. I added a pic for reference). I have purchased new ones and plan on doing it this weekend. The metal mount brackets will need to be bent back so the holed line up.
For those that have replaced these, is there a trick that makes it simple? The mount/insulator appears to be a single piece with a threaded stud coming out each side. This would mean that I have to get quite a bit of clearance between the 2 mounting brackets to remove the old one and install the new one. Is there an easy way to get this clearance? Thanks
Jeremy
Jeremy
