gssixgun
L3600, FEL, SnoBlower, Box Blade, Rear Blade, Forks, Cultivator, Plow
So after blowing a Hydraulic line and misting the entire cab area with a fine spray of slick oil I have a small problem
My Tilt Wheel Adjustment lever is slipping
So I took it apart and found the bolts that look to tighten it, I tightened those down but it is still slipping
My next idea is to take it apart, clean with Brake Cleaner and put it back together..
Is the maybe something I and not thinking off... Thoughts ????
L3600
L3600
