2022 LX3310 seat adjustment
waterwalker
LX 3310
Dec 12, 2022
OR
Does anyone know how this seat is supposed to a be cushion ride. I've played with all the adjustments and absolutely nada!
MOOTS
MX6000
Jun 27, 2019
1,921
2,201
Canton, Georgia
Should be a T handle on the back to adjust the spring tension, on ROPS without backhoe.
nbryan
Jan 3, 2019
1,231
763
Hadashville, Manitoba, Canada
Rops model with T=handle at the rear of seat frame and round knob in front!
Reversible seat for backhoe usage?
That's what I've got, not much cush in the cushion for sure, and the rear handle releases the seat so it can spin to face backwards for backhoe operation.
It has no round knob on front of seat, but there's a round (disc shaped) knob below it that's for adjusting the 3-point hydraulics lowering rate.
waterwalker
LX 3310
Dec 12, 2022
OR
it is not a reversible seat. You are correct on the round knob in front....my bad!
waterwalker
LX 3310
Dec 12, 2022
OR
So I've loosen up that t-handle, and nada again! Looks like the pivot points are frozen in place. Anyone have an idea on how to break these free?
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,346
1,780
Western MT
The seat won't pivot forward?
Fwiw, mine isn't very comfortable. I've heard of putting a lighter spring inside the stock one or using an air shim under the seat. I haven't tried either.
Orange1forme
B2650 HSDC, filled tires, wheel spacers, B2728B , LA534A FEL, 3rd valve kit
Dec 1, 2018
394
57
Wa
The front round knob, located calf high between your legs as you are sitting in the seat, is for the 3PT hydraulic adjustment.
There is a seat forward/backwards lever, under the seat on the right of mine.
There is another lever that you lift and place in notches, in the middle/left under the seat. This is the "bounce" adjustment.
