Deck Dolly
Bugzilla46310
2022 BX2680 198? AC 916H
May 22, 2022
184
185
Demotte, IN
Stole this idea. Should have made this a long time ago. No tools needed. Just use the pins from the deck wheels +2 additional pins. Only thing I may still do is tack the u bolts to the rod so they won’t rotate. You can only tighten them so tight and the casters plate wants to bend. One caster wants to rotate. Other than that, works great. Had the casters and stainless 1” pipe. Got 10’ of 1” rod for $20 and about $20 for the u-bolts.
Chanceywd
Mar 26, 2021
764
722
central ny
After you tack the ubolts, put a second nut on each bolt end to tighten the caster to so it doesn't deform, So that you sandwich the plate between them.
Bugzilla46310
May 22, 2022
184
185
Demotte, IN
The u bolts idea did not work as they would rotate. Had some stainless plate so I made 4 plates and tack welded them to the rods and bolted the casters to the plate.
Downeaster
Kubota BX1880, loader, mower deck, and ballast
Oct 18, 2022
197
Waterford, Maine
Seems a lot of us have the same problem storing the mower deck.. Probably just a matter of time
before some one comes out with a dolly we can all buy to store the mower. I live where there is
a lot of snow and don't like the idea of storing any of my implements outside in the snow.
4,632
View attachment 92028 View attachment 92029 View attachment 92030
Very nice.
I have a similar problem with my brush hog. I'm gonna fab one up hopefully this summer.
Torinodan
T1600, G4200, G5200, Ford 2810, 1974 Wheel Horse C100
Oct 14, 2021
199
94
Fayetteville GA
My decks are small enough for a hand truck. Makes easy repairs to blades and bearings. Just lay it on top and stand it up.
