I didn't see anything about a battery being good. Did I miss it somewhere? I went back over the thread and looked, but still don't see it.
Unless I missed it somewhere, I'm with Henro; the battery needs to be load tested.
ABSOLUTELY!
Because a battery shows 12+ volts, people automatically assume that the battery is fine.
NOT SO!
The OP needs to help his friend remove the battery, take it to an auto parts store, and have it load tested!
I'll bet that battery is shot!
For everyone here on OTT, if you have more than just a couple of batteries, you really should own a simple carbon pile battery load tester.
The 100 amp testers are under $40, and the 500 amp testers (I have one) are under $80 (Amazon).
A 100 amp load tester will prove condition of an automobile or similar size battery, and with no need to actually remove the battery.
