Paralysis by analysis - Buying decision needs wise input!
Vlach7
L47 305DT JD500C
Dec 16, 2021
433
308
Frazier Park Ca
There is lots of great advice here, figure out what you could rent a tractor for, keep it for a day or two and run it hard, the right tractor for the job makes life easier, having somebody come in with their equipment is definitely more expensive in my area. If I am going to run a piece of equipment hard, I want it to belong to a rental yard, yes there is a learning curve, but it will make great memories with the Boys. And in the end, you will have a much better idea what is the best tractor for your unique property and goals.
PaulL
2,675
1,667
NZ
I'm seeing a number of older M series tractors without loaders. Is it possible to add one to these models without them? Also, found a used auction M6060F (no loader) but can't find out what the F designates.
Loaders are very hard to find second hand - if someone has a loader on their tractor they're very unlikely to sell it. You may find one on a wrecked tractor. You can get after market loaders that are more generic. They're OK, not as good as the OEM, but could save some money that way. After market or OEM, a new loader on an old tractor makes little sense. They're expensive, and at the end of it you've still got an old tractor with a loader - you won't get back the money you put in.
It's a pain to wait, but long term it's by far the best way. An old tractor with an old loader will be way cheaper than an old tractor that you add a new loader too.
JerryMT
Jun 17, 2017
529
153
The Palouse - North Idaho
Don't pass up a good tractor because it doesn't have a loader. Do some research and see who makes loaders. Again, I would not advise a loader on a 2wd tractor. The front axles are stronger on a 4WD machine
nbryan
Jan 3, 2019
1,369
896
Hadashville, Manitoba, Canada
Lol I'm running 120 acres hobby farm and bush/forest using only my "little" B2650 HSD and various attachments/implements.
But I'm in no rush, retired, not starting a business (just wrapped my construction contractor business 3 years ago) and the trees top out at around 2 1/2 ft max at stump.
I DO appreciate t how relatively light my tractor is, no getting stuck to the axle, easy pull on a car hauler trailer, no emission controls and great fuel economy with the 26hp 3cyl, 1/2 the price of those 40-60 hp beasties.
It gets it done admirably. Just not as fast.
drumminj
L4701, Mule 4010
Nov 4, 2021
156
119
TN
FEL lift capacity would seem important
(quick internet search):
L-Series: 1200 lbs
L-4701: 1400 lbs
MX5400 & MX6000: 2310 lbs.
M6060 & 7060: 3307 lbs
How heavy is the stuff you need to lift?
Pretty sure the 4701 is 1684lbs at pins, 1263 500mm forward. Standard L is 1131/855 (max height)
5,185
I hear your opinion, but I disagree with it.
Adding an aftermarket loader is frequently a bastardization situation.
Finding a good used OEM loader to fit a specific tractor, is like searching for hen's teeth.
WaltWestbrook
Honda Rancher, Swisher brush hog, teen age boys.
Nov 28, 2022
21
Rhea County, TN
Excellent commentary. Thank you.
Buy a tractor with loader, 4wd (given)...got it. The M6060, or perhaps one of the Mx series seems to be the right direction. I've got searches on all the auction sites, etc. and I'll report back as I go.
3,547
2,138
Here's an M6060 near Savannah on tractorhouse
JerryMT
Jun 17, 2017
529
153
Nothing I said should be construed as buying a "used loader". Most aftermarket loader manufacturers make the attachment hardware for many models so there is no "bastardization" involved. Who do you think makes the loaders for the OEM's ?.
When I bought my '82 Ford 4610 in 1999, I bought a new EZee ON loader with the mounting system that was designed for it and installed it myself. When I bought my NH TD95D it had a NH labeled loader that was made by Quicke who made all the NH loaders at that time. Maybe they still do.
Naturally, if you can find a tractor with a loader on it all ready and the tractor AND the loader is in good shape( no bent up welded over bucket or cracked frames, leaky cylinders, etc) than buy it.
5,185
When I bought my 1989 4x4 Ford 1920 FEL in 2015, I only looked at Ford 1920's that were for sale with OEM loaders.
Tractor was built in Japan (Shibaura), and was originally sold as an OEM Ford tractor/loader.
I was not at all interested in buying a bare Ford 1920, and then dealing with the hassle of searching for a new or used loader that would fit, plus the necessary accessories/fittings to make it all work.
Mountainhill
l2501 (l3800 2013/22), Box Blade, post hole digger, Leon's rear blade
Apr 3, 2017
67
54
Nova Scotia, Canada
Ok, good info. I thought the R-1 was thinner walled and more susceptible to puncture. Frankly I'll probably settle on the tire that's on the used tractor I can find...beggars and choosers.
True, if buying used, you get what’s on the tractor. You may find new, is your best option once you see what’s available and the price of used. When you buy new, you have a choice, as to what tire option you want. If your diving on hard surfaces
WaltWestbrook
Nov 28, 2022
21
Rhea County, TN
Cut the tree down and measure it properly. We want detailed pictures. :)
Turns out my brain box was off by a foot diameter. I measured a few of the big pines circumference today. Largest tree I could get to (lots of brush and brambles around the stand) was 9'6", equating to 36.25" diameter. I think the two big stands of pines are at least 40 years old.
5,185
Turns out my brain box was off by a foot diameter. I measured a few of the big pines circumference today. Largest tree I could get to (lots of brush and brambles around the stand) was 9'6", equating to 36.25" diameter. I think the two big stands of pines are at least 40 years old. View attachment 91671 View attachment 91672
You obviously have lots of pine lumber just waiting for you.
I would suspect that they are a lot more than 40 years old.
WaltWestbrook
Nov 28, 2022
21
Rhea County, TN
While probably not surprising to y'all, I just got back from the dealer and a new M6060, 3rd function, no cab, Ag tires (filled), is not much more expensive than a 2 year old version with low miles.
I asked about a cash discount and was told there really isn't one, as I'd guess they make more money on the financing kick back.
Anyone want to forecast when, if ever, the used tractor market might start coming down?
jyoutz
Jan 14, 2019
3,495
2,583
Edgewood, New Mexico
It has never been real cheap to buy used. Twenty years ago, a used tractor with reasonable hours and in good condition would bring 75% of new.
