Gear heads
3,329
First off thank you for the advice on the heater so far it is working stellar. Now a real dumb question I think I may know the answer but I have to ask anyways. Due to my neglect the pressure in my tires was low, and the display on the dash of my Silverado was showing the numbers. So I puled out the compressor and filed them up. Put air in the driver front, and it was still reading 30psi, like it was when I started, so I pumped in some more thinking my filler isnt working frozen up or something,, nope checked again and lo and behold the driver side rear was showing 50 psi, on the display. HUH???? I only had one tire I was filling and the display showed the wrong tire,, OK let air out to 35, in the front and the rear showed 35 psi. Went to the rear pumped to 35 and the display showed that the front tire had inflated. The same thing on the passenger side.
I know its not a big thing but any ideas why it is reading like that ?
Fordtech86
L3200
Aug 7, 2018
4,976
5,917
Pineville,LA
It doesn’t update instantly, some of them you have to drive a little bit too before they will update on the dash. It shows the wrong tire likely do to it having tires rotated or replaced at some point and tire positions not relearned to the truck.
6,596
Seems like if it's registering for a different position then the one your filling then the TPS monitors are mislabeled. Or perhaps the tires were rotated. 🤔🤔🤔
I would just check and set each tire per what the actual tire gauge reads and not go by what the monitor shows on the dash.
Haven't had one show up on my GMC yet so I couldn't tell you if it resets immediately or if you need to drive for a bit to reset it.
motionclone
May 4, 2018
1,398
996
Maine
Maybe you have iSmart schrader valves and the air you are putting in is being diverted wirelessly to the tire that needs it the most
Winkles_9
Kubota L3301
Jun 24, 2021
29
Annandale MN
I just had this problem with my suburban. If the tires are rotated, the car doesn't know the position of the tire anymore. You need to code the truck with a tool to each tire. There are plenty of videos on youtube to show you how to do it also.
armylifer
Mar 26, 2013
2,051
784
Thurston County, WA
i also have a silverado. My owners manual outlines the procedure to manually update the TPMS system so that each tire is registered to the correct position on the truck. It involves turning the ignition key on and off a couple times and using the setting buttons in the truck and letting air out of each tire in turn, starting with the driver side front tire and listening for the horn to sound when each tire is registered. After that procedure you need to put air back in each tire to the correct pressure and drive a short distance. The correct tire pressure will then show on the dash. My Silverado is a 2007 2500 Duramax. Other models and years may differ in the procedure. Check your owners manual. Since it sounds like you have the 1500 model, here is a link on how to reset your TPMS.
4,816
Put my winter tires on last Saturday, and they had to be programmed into the car. The machine that was used didn't recognize the sensors in the valves, but the car did. Marked the summer tires so they will go back on in the same place as they came off.
Fordtech86
L3200
Aug 7, 2018
4,976
5,917
Pineville,LA
doesnt matter, they still gonna have to be programmed back…
edit: this is if you have seperate wheels/sensors for each set of tires. If it’s just a tire swap then wheels need marked or reprogrammed for position when swapped back (if it’s a vehicle that does display individual tire pressure or has a different pressure setting between front and rear tires)
3,329
JEZZUS BLOODY KRIST,,, this is more than should ever have to be on a truck !!! Aww well it is what it is I guess,, Ahh the heat yeah well like you guys said the sensors out side and inside were doing what they were suppose to do, so it is cold it blows hot till it warms up in side then regulates the temp like it should be. To much computer stuff to worry about,, and evolution marches on ward
Mark_BX25D
Bx25D
Jul 19, 2020
1,756
1,278
I wouldn't even think of filling my tires according to a TPMS system. They are notoriously inaccurate. I pay zero attention to it unless there is some sudden change. Then I use a quality gauge to investigate.
GSD-Keegan
B2601 with Fel and Bh70 backhoe
Mar 6, 2021
611
808
Ontario, Canada
Wife’s car dash readout is showing all four tires at correct air pressure…but the dash keeps chiming and flashing low tire pressure warning. All four tested with gauge and ok!! 😡😡😡 hmm, just had a brain flash…maybe it’s the full size spare ???.
6,596
That's why I just use my manual gauge and check each tire if one is showing low 😬😬😬
6,596
Might have one on your spare, or the batteries are getting low.
4,914
TPMS is one of the worst 'safety' items ever put into vehicles. It's hard to implement,hard to relearn when a tire is swapped, does next to anything for safety(readings can be 5PSI off, for sure 2PSI ) and EASY to bypass(fool)
As for putting tires back where they were, I swap mine every 5K,old skool X pattern and get a LOT of extra miles on them. IF you swap often, no 'ride/wear' issues.
BXHoosier
BX24
Jan 21, 2018
484
556
Indiana
I bought a cheap TPMS relearn tool since I have separate winter and summer tires for the truck and the wife’s car. GM vehicles after around 2012 have to have a tool to relearn the sensors.
4,914
It's too bad 'they' just don't use a 'smart' TPMS computer. Takes about 200 lines of assembler for the 'computer' to figure out which sensor is at what wheel location, then 'lock them in'. When tires get changed ( twice a year...or a flat..), the smart computer KNOWS this and makes the appropriate changes.
dlsmith
BX2230, LA211
Nov 15, 2018
1,235
789
Goshen, IN
Oh sure, they COULD do that, but it would probably be a $2000 option.
